Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
The dishwasher stopped working after one use. doesnt have and water running through it.
    Brigadier General:
  • 4,088 Answers
Make sure the under-sink water connection valve didn't get turned off by someone. Also, check the entire length of the inlet water line for any kinks or pinches. Does the machine make a loud 'click' (the inlet water solenoid) when it calls for water. If no click and no water comes in, remove the lower front panel and inspect the water solenoid--it should have two wires coming to it. If ok, suggest calling for warranty service (if machine is new) at this point. Good luck!
Posted on Jul 07, 2010
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Bosh diswasher SHE45M02UC/48 doesnt stop when I open the door
That is the drain pump that is running, and it indicates that there is water in the base of the unit. You will need to unplug the dishwasher and pull it out. You can tip it forward to drain the water out of the bottom through the holes in front. Have some towels ready to catch the water. Now if you plug the dishwasher back in, the pump should not run But now comes the hard part - figuring out where the leak is coming from and fixing it. It could be from a hose, the drain pump, or the main pump. Bosch dishwashers are notoriously hard to work on, so I recommend calling in a professional DW repairman.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 25, 2015 | Dishwashers
My dishwasher has stopped working, water goes out but doesnt come in so it doesnt wash, can you help?
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 17, 2011 | Whirlpool 24 in. ADP5740 Free-standing...
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
My kenmore washing machine fills with water but will not wash..it sounds like its doing something then it stops after a while i hear it drain and then stops again..water doesnt spray..I let the dishwasher...
Often these work by reversing the motor which has two pump impellers. One direction will pump the water out and the other will pump it through the spray bar. IF the one pump impeller has broken then that would explain your symptoms.
If this is the type you have, verify that the motor is running reversed from when it is draining. If it is not running during wash time, then the timer is probably at fault. If it is running, check for broken pump impeller for the was direction.
Sep 29, 2009 | Kenmore 24 in. 16193 Stainless Steel...
Doesnt empty completely, a pump is running when
it is normal to have some water come back in from drain hose(not to worry)
Aug 23, 2009 | Whirlpool 18 in. ADP530 Free-standing...
Water pump doesnt stop running
bottom tray under dishwasher holds a cut out switch.this is activated when there is a leak from unit which fills the undertray.
Dec 14, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
BEKO D 2731 FW Dishwasher Problem
possibly due to water in the sump tray. tilt machine back at 45deg and see if water runs out. if it does and you get rid of the water that way, then the machine should operate. if it reoccurs, then you have a leak
Jun 21, 2008 | Dishwashers
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
59 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
