Keeprite 2300 sx a/c w/ 2 speed fan never seems to go high speed .should I be able to hear it change and how do I dainose the problem ? and does this cause poor cooling ? the compressor unit line is cold and sweating outside the A coil is cool not cold the small line is warm but not hot the unit will not cool past 24C it is 30 C outside and continues to run making no difference in temp, set the temp at 25c it will cycle and cool .the gas charge in the system is correct pressure this is an R22 unit also have not been able to find wiring diagrams on line for this unit if you could help that would be great Thanks Ed
  • Heating & Co... Master
  • 1,657 Answers
I need more info. I can't seem to find your indoor unit. Is this a 2 stage cooling unit or just 2 speed fan? Please send the model number of your indoor unit.
Posted on Apr 11, 2017
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
  • 121 Answers
SOURCE: coleman rv a/c
It is definitely with the compressor. It should more like you may have a weak winding in the compressor, you can a hard start capacitor (sp5 ) that will help the compressor on restart. Note that this is a last chance solution for a compressor.
Posted on Oct 01, 2008
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 148 Answers
SOURCE: outside compressor off while handler on inside, no cooling
Posted on Jun 20, 2009
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
I have a new spa with a Pentair Mastertemp 125. We have had issues with the heater running intermittently and making a very loud rattling noise. I've been through a long list of troubleshooting...
Maybe that at lower pump speed the water is staying in the heat exchanger too long, and the rattle you hear is water starting to boil. The high limit sensors will sense the water temp being too high and shut down the heater. If it functions normally at high speed the issue is probably with the heater having problems with slow flow through the exchanger. You may want to consider switching to an electric heater where this would not be an issue. Just a guess without being there.
Jan 18, 2015 | Pentair Pool & Spa
Blower motor doesn't pump well even the fan switch on high
sounds like blower bearings are dried out and will eventually lock up the blower..sometimes you can spray wd40 in the blower bearings and it will work fine for a while.. also check vacuum controls to the baffle dors in the ductwork..may have some leaks there.. should hear a slight hissing if really bad..repost findings
Feb 09, 2013 | 2005 BMW 545i
Keeprite furnace will come on heat up but the fan or blower doesn't blow but creat noise. please tell me how can I fix it. Regards Andre
Blower motor is either burnt or Ihave also seen the fan relay on the board burnt..test for 120v power out of the board at the blower leads if so replace motor, of no replace board
Feb 06, 2010 | Omega Keeprite Furnace Flue Exhaust Venter...
I can't seem to change the fan speed regardless of
it usually pre set buy FAU it high for cool low for have to go into fan cabinet and their set of wires red and black for high low some have 3 speeds.but will state on wire diagram.
Jul 05, 2009 | Heating & Cooling
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Jun 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
