Question about LG Vu CU920 Cellular Phone
CHARGING I CAN CHARGE THE PHONE OVERNITE. AFTER A FEW PHONE CALLS THE PHONE HAS TO BE CHARGED AGAIN.
    Guru:
  • 19 Answers
Seems like your phones battery is weak. Try these to increase the battery timings:
  • Let your phone to completely draw its battery, once its fully uncharged then recharge it completely and then use it. That will prolong the talk time and battery life too.
  • Lower the brightness of your phone, that will result in less consumption of battery.
  • If it does not helps then consider buying a new battery, but hopefully that wont be needed.
Thank You!
Posted on Jul 07, 2010
Problems with htc phone
The battery is not charging on my AT&T Windows 8X. How do I know its charging. I've tried the hard reset and I get to the ! point and push the buttons in the order it tells me, but it does not reset. I just noticed even though I thought it was charging overnite, that it is not charged which may be why its not rebooting, I dont know. It just keeps flashing the HTC logo on the screen and goes black, then does it again. After seeing the battery charge indicator in the red, could it be that there's no power to reboot????
Jan 02, 2014 | Cell Phones
How long does it take to charge jazzy select gt
Mike it depends on the charger and how discharged the batteries are. But if you get into the habit of charging it overnite when you get up in the morning it should be good to go. A 3 amp charger will take longer to charge than a 4 amp or 5 amp. Now if you are charging overnite and still don't get a full charge then you could have battery problems ie one weak battery causing the chair not to get fully charged or it could be the charger but if the charger has been doing ok in the recent past then I would have to suspect the batteries Hope this helps
Feb 19, 2011 | Pride Jazzy Select 6 Indoor Power...
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose?...
Wez Thats a normal indication of a full charge. The battery level indicator will go down as you use the scooter. Always charge the scooter overnite if you use it a good bit during the day. With new batteries it will take 8-10 charging to break them in and operating at 100%. Always store fully charged and if not used alot charge once a week after you have charged the batteries 8-10 times
Hope this helps
Oct 27, 2010 | Drive Medical Phoenix 3 Wheel Compact...
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
I have a 2000 Buell Lightning X1 and am having problems with charging system. Batt. is good but it's not getting charged. I have no idea what it could be... Need help...
Check your fuses, if they are good check your battery connections, are they good and tight? no corrosion? Charge the battery with the cables OFF OF THE BATTERY. Make sure it charges overnite. after it charges check to make sure the battery is still over 12volts. let it sit for a few hours and check it again to make sure it is STILL over 12volts and has not dropped at all. If it has replace the battery. anything further and you will need the Buell factory service manual - do a google search for it.
Sep 07, 2010 | Buell X1 lightning Motorcycles
Fully charged cellphone battery drains in a few minutes
relpace your mobile battery and avoid overcharging and charging overnight
May 22, 2009 | Motorola Mobility MOTORAZR maxx V6...
I870 battery or phone problem???
you bought it off ebay --your battery probable at fault but also depending on what you have -running or downloaded apps-photos -music will drain battery in stand by mode even if you replace battery if your usage is high [dont have to be on phone ] from what you have on it battery drain can be the same
Apr 19, 2017 | Motorola Mobility i870 Cellular Phone
I cant use the phone.
Is the battery in the phone charged?
when not in use leave it in its holder so that it is kept charged.
How old is the battery?
If after charging it still makes no difference then you need to buy new batterty as the old battery won't be holding charge.
Oct 14, 2008 | Uniden Cordless Phone
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
LG Vu CU920 Cellular Phone Logo
145 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
