Question about HP Computers & Internet
Monitor troubling by changing the menu settings by itself
  • 570 Answers
If the monitor only displays 640x480 & 16 colors, it sounds like the display adapter is using standard windows svga drivers. (Unless you have a VERY old monitor that can't display more than that.) Have you tried reinstalling the drivers that came with your video card ?
Click on "start", then "Run".
type in "msconfig" (no quotation marks)
It should open the system configuration-thingy.
If it is set to anything other than "normal startup" (ie diagnostic startup), change it back to "normal startup". Click "apply", "ok", and then restart your computer. You will hopefully be able to change your settings again.
If everything fails change your video card
Thanks.If this solution works for you then please rate me.
Posted on Jul 07, 2010
Monitor screen has shrunk down from top and up from bottom
There has to be a setting in the menu for the monitor...I would look in the menu in the monitor settings on the monitor itself, and find a reset selection, to set it back..
Oct 06, 2014 | Samsung SyncMaster 931B 19" LCD Monitor
Osd appearing without pressing any buttons
What's going on is either a misconfiguration on your video card, your monitor settings or a cabling/connector issue. A signal is being sent to the monitor it doesn't understand. You're going to have to play with settings and if you're using an adapter in your connectors, that could be the problem too.
Mar 29, 2014 | LG 22" FLATRON LCD Monitor
Why my monitor screens is color green
Your RGB settings has most likely been altered, resulting in some problems. Check your settings menu on the monitor itself and reset the settings to default. If that is not the problem, it's probably the computer's settings that has caused this change. You will need to go to the computers monitor settings and reset that to default to get back to normal colours.
Nov 04, 2012 | Samsung SyncMaster 915N 19" Flat Panel LCD...
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
The right hand 1/3 of the screen is blank. Cannot get anything to display
sounds like you have to set the monitor resolution using your computer. right click desktop... graphics options. or Properties. look for Resolution slider. Move it around. press apply. see what happens. if it now fits but is fuzzy. change the refresh rate eg. 60 Hz or 75 Hz. On the monitor itself there is typically a button that allows you to move the image to fit the screen, quite often these settings are inadvertently played with by children ect. look for buttons/ menu's on your monitor itself. play with the settings .
Aug 24, 2010 | E-Machines eMachines Monitor E15T4
How do I change the contrast on my monitor Acer x193w
mcdevito75 here, Press the AUTO button on the monitor under to lower edge of monitor itself. This restores factory settings, if you still want to adjust, press MENU button then use left / right arrows to adjust picture quality.
Jul 19, 2010 | Acer V193w LCD Monitor
Menu items do not adjust. I think I need a manual. ? do I need a driver for this monitor? It seems to be working without installing a driver. sdm-hs75p
All addjustments are done from the monitor itself with the buttons on the monitor. It's a matter of knowing which button does what. Generally there will be the arrow buttons and then a menu button, and of course the power button. This monitor should also have an OK button. This should save the setting you changed.
Jan 08, 2010 | Sony Computers & Internet
5 sec after starting windows the monitor goes to sleep itself.
go to safe mode.. change the power settings for windows...
to go to safemode.. simply restart your computer.. then press f8 several times til you see the boot menu.,.. select safe mode.. from there.. you should be able to boot windows.. change the power settings in control panel
Jul 09, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Display menu virus? :(
try disconnecting your network cable and adjust the settings again, if you cant, enter safe mode by pressing f8 in the startup and select safemode then adjust the contrast there.
Or is this in the CRT monitor? inside the monitor? there are no viruses ever made for monitors. So its most likely a hardware fault in the crt. Maybe its time to buy a new one. LCD preferably easyer on your eyes.
Apr 28, 2008 | AOC 7F 17" CRT Monitor
Computers & Internet Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
