Question about Nikon Coolpix L11 Digital Camera
I broke the display panel and i need a new one con you send me one an how much cost me? I can replace de oanel.
    Novelist:
  • 145 Answers
If you can, carefully take your camera apart and remove the old screen, Look at the numbers on the back of the screen and ebay them, If your unfamiliar with how to remove a camera screen you can try and ebay soomething like " LCD+nikon coolpix l11 " and see of your able to find a LCD screen replacement. Most screens are under $20. The biggest thing if your doing this is to be careful with the screen connection and the little tab holding the screen cable in. Take your time and you will have little to no problem.
Posted on Jul 07, 2010
I have a Samsung Model LN32D450G1DXZA LCD TV with 2 thin white vertical lines on the mid left side of the TV, going from the top to the bottom. It's not horrible but it is annoying. I was advised to...
The T-con is part of the panel. You can check your cable connections between the T-con & the panel & check the panel connections(may have corrosion) Otherwise, you will need a new panel, in which case you replace the TV, as the panel will probably cost more than a new TV.
Mar 03, 2015 | Samsung Televison & Video
Olevia 237 s12
possibly the I/O PCB, but more likely the panel & not cost effective. check the wiring between the T-Con & Panel itself.
posiblemente el I/O PCB, pero probablemente es el panel y es demasiado caro por nada mas repararlo.
verifique q esta conectado el T-Con con el panel.
May 01, 2014 | Televison & Video
Spark plug wire failure
Put new one if not catalytic con. will be next.Could cost $500.00+
Jun 19, 2013 | Cars & Trucks
When turned on it has no picture but sound works
hello!
if your TV stays on, display glows, but there is no picture, most likely you have faulty t-con board and/or display itself. I've encountered the problem with both lately. I'd start with t-con(display adapter) board. it's not hard to replace and cost around $100 top. If that won't solve the problem, then it's a display panel itself. not an inverter, which is the part of power supply, but panel itself. Before replacing t-con, try to reach display's ribbon cable connectors, plugged into t-con board. disconnect first one and turn set on. If you see half of the picture, the display is bad.
If nothing changes, reconnect that cable and disconnect another one. If you see half of the picture, display is bad. If, still you don't get any picture, that's your lucky day! Display is good, t-con is bad. Replacing the display panel will void any reasonable repair option. Those crooks at "parts distribution' selling displays at the price of your TV, when you bought it: $1,500-2,000+. i don't understand why do they practice rip off. most likely to encourage customers to buy new junk and receive hefty bribes from "peoples republics" to stay in business. Anyway, it's a crazy globalism. that's why our country in default.
good luck with your project,
thanks,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Picture shattered with black and colorful lines, is it fixable?
hello!
unless the display panel has been physically damaged, which it seems by your description, replacing t-con board or trying to reconnect panel's ribbon cables first, may solve the problem. otherwise, the cost of new panel voids any reasonable repair.
Good luck,
Alex.
Nov 25, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My LG led has had several problems, it started out with the left half of the screen flipping as if viewed from a mirror with the right part of the screen normal. After that, it displayed vertical colored...
This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
May 31, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
How to remove Maxent L2614XW02 lines on screen
do a reflow to the image board and concentrate on the chip with the green heat sink on it, that chip is faulty, i did this and has been working great
Jun 02, 2010 | Maxent Televison & Video
I need a new screen
A new screen will cost as much as a new set. That is the complete LCD display panel.
Feb 01, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
THE SCREEN OF MY TV IS BROKE,.HOW I CAN FIX?
You need to repalce the whole LCD panel, it will cost you more than the net is worth.
Dec 13, 2009 | RCA L32HD31 32 in. LCD HDTV
There is only about 2/3 of a picture being displayed on my tv. The right 1/3 is just black.
Sounds like you may need a T-con board if available,Sometimes it only comes with the whole panel assembly.If the T-con is available it may be worth repair,if not the cost of the panel will probably exceed the cost of replacement.You may be able to reseat the flat "ribbon" cables on the board and correct it.
Nov 04, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Nikon Coolpix L11 Digital Camera Logo
85 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
