Question about Midland LXT80 Two Way Radio
Opening battery compartment on Midland LXT80 2-way radios
I have a set of Midland LXT80 walkie-talkies. How do I get the battery compartment cover off to replace the batteries?? I've tried sliding it, squeezing it, pulling at it, all to no avail!
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Posted on Aug 19, 2010
  • lisaoc992 Oct 28, 2010
    Thank you. Worked great
    New Friend:
I just had the same question. I started to think that it had a rechargeable battery and that the battery compartment could not be opened. However, it does have a battery compartment holding 3 AAA batteries. Just push in and down very hard and it will slide/pop off.
Posted on May 23, 2016
    New Friend:
Unscrew then push down and pull down on the battery compartment and this should do it.
Posted on Jul 09, 2013
WHAT bATTERY USE FOR THOSE WALKIE TALKIE
Here is a link to the manufacturer who can help you get the correct batteries: https://midlandusa.com/product-category/accessories-two-way-radios/
Also, a quick google search shows several alternate sources.
Apr 09, 2015 | Midland LXT300 (14 Channels) Two Way Radio
One walkie talkie will send but not receive
Check your programming, specifically the private line (PL code) settings. This is one problem which can cause the problem you are describing.
Feb 22, 2014 | Midland Radio Midland Gxt 795 Vp4 Radio...
I lost my manuall for my GXT walkie talkie
Look online for the manual, I found my refrigerator manual online,
Jul 04, 2012 | Midland Radio GXT760VP4 - X-TRA TALK GMRS...
I bought 6 sets of Midland LXT 345 walkie-talkies for the teachers to use when they go out on the playground. Less than 1 year later several of them don't work. They keep them in their charges when...
The batteries have likely been damaged from being on the chargers too long. Try trading a known good battery into the non-working radios and see if it/they will work with a good battery. If so, replace your batteries, and then only put the radios on the charge when they need a charge, such as after the radios have been used 8-10 hours. Longterm charging can quickly age batteries. Life expectancy of a battery is 18-24 months with good care.
Best regards.
Sep 23, 2011 | Midland LXT385VP3 Two Way Radio
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
One of my midland lxt 420 walkie talkies wont charge!!!!!
If it has rechargable batteries in it like mine does, the batteries have probably lost all of its life.. you can replace them.. if you dont have batteries, you could have a loose wire inside the walkie talkie that wont let it charge..
Jul 29, 2009 | Radio Communications
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Midland LXT80 Two Way Radio Logo
4,596 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
