Question about Samsung Washing Machines
My samsung washing machine is not working, i mean only the spinner i am able to wash the cloths but the spinner is not working, i need a technician
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
SOURCE: samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Posted on Feb 15, 2008
SOURCE: samsung b1245s washing machine
Error code is actually 5e and is to do with your drainage being blocked. Check the flap in the lower right of the machine. Open and unscrew the big black wheel/cog thingy (make sure you get lots of towels or drain all the water first with the little pipe to the right of the big black wheel/gog). I found a few coins trapped in my pipe and its working a treat now I cleared them out and spent them on lots of sweeties. Yummy. :D
Posted on Aug 19, 2008
jrwoodlock
  • 19 Answers
SOURCE: My Washing machine stains clothes;
Its the felt drum seal (clothes getting stuck in there and getting the greasy adhesive on them). I took a Q-tip and slid it between the felt seal and the metal, and the color and consistency of what came out was the same as the marks on the clothes.
Call a Whirlpool tech, they can replace
Posted on Aug 21, 2009
IFIXALL
  • 868 Answers
SOURCE: I have a MHWE500VW11 when I am washing my clothes ...
Pressure switch / pressure hose issue > By, Tech : Archie Ferrarini
Posted on Aug 04, 2010
My washer is not thoroughly spin drying the clothes. I have to run it through 2 or 3 times on the spin cycle to get the clothes not to be dripping. It is 19 years old and just now started doing this.
it may be your agitator. 1
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Jan 31, 2011 | Kenmore Washing Machines
The round gray rubber seal that the door shuts into between the door and the clothes spinner is collecting mould/greese everywehere. How do I clean the problem up and stop it from happening?
The rubber seal is already loose and degrading which causes the dirt, it needs to be replaced... the replacement is tight... have it checked by a technician to replace it with a new one.
peace...
please rate..
Jan 31, 2011 | Washing Machines
My Sharp Washing Machine ES-6515TS still drains even if the drain control is already closed and sometimes water goes out to the spinners tub.
PROBABLY THERE ARE THINGS THAT BLOCKING THE DRAIN, IT MIGHT BE COINS, PARTS OF CLOTHES, PANTY OR HANKY. SIMPLY OPEN THE BACKSIDE OF YOUR WASHING MACHINE, UNSCREW THE DRAIN LINE COUNTER CLOCK WISE TO OPEN THE VALVE FOR DRAIN. YOU'LL BE AMAZED OF THINGS PRESENT INSIDE THE DRAIN VALVE. AFTER THAT IT WILL BE OK FOR YEARS. I BROKE MY SPIN DRY MOTOR AND RUBBER BELOUSE, FUSE 3X. SHARP TECHNICIAN CAN'T FIND THE PROBLEM WHICH I DID AFTER 5 YEARS. I HOPE IT WILL BE HELPFUL TO YOU.---ROMMEL OF MANILA PHILIPPINES.---rtlagasac@hotmail.com
Jan 09, 2011 | Washing Machines
It does not spin. Checked the coupler and it is
Sometimes the spinner stops if they are water remain or small cloth pieces. Dry out the spinner completely first and check for any cloth pieces or particles.
Mar 19, 2010 | Roper Washing Machines
The machine is not spinning properly after the wash and the clothes are left wet and sometime the machine is also full of water. If the problem is with the spinner how much would be the repair cost! Thank...
i want you to watch the control
check your lock light
full off water usually means it is not pumping properly
i would remove the back panel
unplug the machine
once the back is off
you will see the pump disconnect the ealectricla leads and the two hoses
turn the pump and pull up it locks in the bottom
on the twist
make sure the pump and both hoses are clear
if it were the spinner you would be noticing other things
Oct 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Apron stuck under the spinner
Hello blubear0105 ,
Download the Service Manual and take a look at Page 37 “Tumbler Removal” You will need a #20 Torx driver to remove the tumbler the SM doesn’t call that out. It’s easy to remove, post back if you have any questions. Rich
The Service Manual for reference. Sears Parts Direct for reference.
Oct 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking from spin dryer in washing machine samsung swt65b1p . leaking from shaft underneath spinner unit
sounds like the seal on the tub is shot youll need to replace it (easier to have repair shop do it unless your real couragous)
Aug 23, 2008 | Samsung Washing Machines
Washing machine problems
Oil or grease due to failing seal on the drum shaft.
Jan 14, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
