Question about IBM ThinkPad R31 2656 Notebook
Buttons? I have an IBM thinkpad R31 2656 and was wondering how to get the volume and the thinkpad buttons to work, any help would be great thanks.
  • Anonymous Jul 31, 2008
    keyboard problem
U can load the driver of that button. i have a same laptop i load the driver then it work
Posted on Apr 26, 2008
    Guru:
  • 1,342 Answers
Try them while holding down the Function key.
Posted on Apr 18, 2008
Very weak sound from ibm t42 thinkpad - internal and exteranl speakers
There are two ways to set the sound on an IBM thinkpad, hardware and software.
Hardware sound can be set via the speaker buttons below the screen. There should be three buttons: Mute, Volume Down, and Volume Up.
Software sound can be set in windows through the speaker icon on the bottom right of the screen. Click on the icon, and drag the slider up or down to change the volume.
If you don't have the correct drivers installed, these two settings are separate (e.g. It is possible to have the hardware volume down low, and the software volume set really high, and still have music playing relatively quietly). I would suggest turning both of them up and see if the sound gets louder.
Mar 07, 2011 | IBM ThinkPad T42 Notebook
No sound ibm thinkpad t30 windows xp sp3
After checking the obvious (volume control mute not checked, volume slider not all the way down, and volume button on keyboard is not pressed to mute) -
Go into Control Panel, system, hardware tab, device manager, Sound and Video Game controllers, and delete the sound card. Reboot your system. Windows will find the sound card and re-install it.
Hope this helps.
Aug 14, 2010 | IBM ThinkPad T30 2366 Notebook
Audio coming when connecting headphones but not coming out of speakers for ibmt41thinkpad please reply on ibm thinkpad t41
There are volume buttons above the key pad - a volume up, down and mute button. Have a check with those once. Unmute or increase the volume and check
May 20, 2010 | IBM ThinkPad T41 2373 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
Ibm t41 sound not working
Just to try the obvious...
The volume buttons on the laptop underneath the screen work independently to the volume controls in Windows. Have you tried pressing and holding the volume up button and then playing a sound?
Jan 21, 2009 | IBM ThinkPad T41 2373 Notebook
Volume&thinkpad button
Most IBM / Lenovo Thinkpads have hardware volume control with apropriate buttons above the keyboard (volume up, down and mute). Gnome in Ubuntu is configured in such a way, that the keypresses are trapped (this is correct), apropriate volume window is displayed (correct) and Gnome volume control is modified. Last step is actually wrong - the keys in Thinkpads control the volume hardware directly, so every keypress turns the volume up/down regardless of sound card settings (in Ubuntu case - this would be Alsa mixer). Current behaviour results in volume being changed twice - for example if I press the volume up button, I get volume reduction via Gnome sound mixer plus volume reduction via hardware control. Effectively this creates an exponential (and not linear as it should be) volume change. In short - it is very difficult to control volume, especially relatively quiet sounds, with volume keys only.
The "patch" solution is to decouple Gnome mixer from hardware buttons. Of course it could be done manually, by deleting apropriate key actions in System->Preferences->Keyboard shortcuts, but this also disables windows showing volume. A better thing (but more complex) would involve reading /proc/acpi/ibm/volume and displaying the volume window according to this value at each volume button keypress.
I tested this on T21, T42 and Thinkpad 600. I guess only some R series notebooks (R31 etc.) would not be affected, as these do not have hardware mixer.
Steps to reproduce:
1. Press hardware volume key (eg. volume up) on a Thinkpad
2. Observe the volume change - it is changed in hardware mixer (correct) and in Gnome volume control (incorrect)
I hope this helps...
Apr 18, 2008 | IBM ThinkPad R31 2656 Notebook
Volume buttons
Click to "Access IBM" button , Thinkpad Configration window or webpage, Thinkpad Configuration program will appear.
GoTo : Thinkpad Config->Display->On Screen Display
You can see there or it may there on some other option, on this configuration program. It may help you.
Cheers - Parveen
Feb 06, 2008 | IBM ThinkPad T41 Notebook
Ibm thinkpad g40 support
Your laptop comes with a recovery partition. You can reinstall the drivers for this through it.Your documentation will show you how.
Jan 12, 2008 | IBM ThinkPad G40 2388 Notebook
Sound output not working
Laptops Have a Digital Volume Control.
You have to hold the fn key and press the speaker shape+ or a speaker shape X (no sound button).
Nov 12, 2007 | IBM ThinkPad R50p Notebook
Cracked TFT screen on IBM Thinkpad T21
HERE IS A LIST OF P/N THAT WILL WORK
46L4843 LCD 14.1
05K9942 LCD XGA 14.1
05K9678
05K9668
05K9567
05K9944 ALL SUB TO 04L2348
Oct 16, 2007 | IBM ThinkPad T21 2648 Notebook
IBM ThinkPad R31 2656 Notebook Logo
264 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
