Question about Lexmark X125 All-In-One InkJet Printer
My printing problem is not a constant thing - it seems intermitent. Sometimes when I want something printed and get no result, I see the icon of the "x" (delete) in the lower right hand corner of my computer. The only way I can correct this to print is to re-start the computer so the icon disappears. Sometime back, I downloaded a driver and thought perhaps the problem was solved, but it started happening again. Frustrated - what to do????
  • 518 Answers
May be the data transfer to the frinter,cables secure, driver compatability if it win 7, its to do with how the computer sees the printer and feeding data to it
Posted on Jul 07, 2010
The light on the left of my printer is blinking
hi, sometimes this results to documents that are pending and didnt finish to print. try to cancel the documents on the print tasks and try to unplug the printer then plug it again to get rid of the light and start printing again. hope this helps
Feb 19, 2010 | HP DeskJet 970cxi InkJet Printer
Prints icons instead of document
Sometimes the drivers can get corrupt, or even sometimes the printer cable is just not plugged in snuggly. I would check all the connections to the computer. Goto http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=ML-2150&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010400&disp_nm=ML-2150&model_cd=&menu=download and select your operating systems. Save the file somewhere you can remember. Then goto Control Panel\ Printers\ Add A Printer. Go through the add printer wizard until it asks for the drivers and select "Have Disk" browse to where you saved the drivers and select the driver and click OK. Click next and finish and try printing a test page to the new printer. It will probably have the same name as before with a (1) after it. The only other thing I can think of is if maybe it is only having these problems when printing from a specific program then you may want to run a disk check or defrag and see if that helps.
Apr 27, 2009 | Samsung ML-2150 Laser Printer
Print to small on hp deskjet printer
Reinstall the driver, hp constantly updates their drivers, with bad drivers sometimes itwill even print the "wingdings" font instead.
- Canis
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
Cant print off compute
Hi Grubeman,
The issue seems to be with the printer drivers. To confirm whether the issue is with the printer drivers or with the application, try to print from all the other applications and check for the result.
I have two solutions for your issue.
1. Set "print directly to the printer" option
2. Alternate drivers.
To set the Print directly to the printer option, do the following steps.
1. Open the printer folder
2. Right click on the printer icon and select properties.
3. Click on the Advance tab and select "print directly to the printer" option.
4. Click apply and ok.
5. Nothing else, just try printing dear!!
The second solution, I will post, once I found that the above steps does not resolve your query...
BYE.....
Feb 05, 2009 | HP Officejet 5610 All-In-One InkJet...
I can't seem to print borderless photo prints
Ok,
After going back and forth with Hp which by the way were very helpful I still did not get a fix. I decided to go to "Control Panel" Clicked on "Printers and Faxes". Right clicked on my printer icon and deleted it. Then I clicked on "Add a printer" I added the C5180 again and now it works great. Don't know why and I don't care. Just so it works again. That's the nature of computers sometimes. Thanks
Feb 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper feed and printing problem
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
How to get a HP LaserJet 1018 to actually print something?
Yes it is a print driver problem, Unplug usb, delete all previous attemps at install, delete print software and drivers, Download and install correct driver from HP, plug in usb only when directed to do so.
Dec 18, 2007 | HP LaserJet 1018 Printer
Prints continuously
sounds like when it wasn't printing properly, you tried to print several times, not realising that prints which were not printed at the time were being stored to print when the printer was available.
you need to check the print queue, by clicking on the printer icon in the bottom right hand corner of the screen(by the clock)
you should be presented with a list of pending documents, which you can delete or suspend as required.
if the printer icon cannot be found next to the clock you can find it under START>settings>Printers
Oct 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
Printer Does Not Print.
What are the operating systems of the computers? Have you checked that the printer is supported by these operating systems? There appear to be issues with Vista computers for driver for many peripherals Suggest you contact HP rethis one By the way your Screen shot that mode is it? I dont seem to be able to open it with the regular programs.
May 23, 2007 | HP DesignJet 3800cp InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
