Question about Nikon D80 Digital Camera with 18-135mm Lens
When I put on the D80 Nikon camer with 18-55 lens showing err 10 or 11 in small display in place of frame counter. Otherwise auto focas work, even camera klik but picture not expose then what is the problem ?
    Champion:
  • Nikon Expert
  • 225 Answers
Hi nrkelkar, In the D80 manual page 36 it speaks about the buffer. What you see as an error message is r with a number. The number is how many shots the buffer at that moment can handle. It is not an error message.
Posted on Aug 25, 2010
Keeps showing err but can't find solution.
usual cause: failure of the phase switch in aperture unit. the gear with contacts (one of the plastic rivets beaks and contacts will not stay in place) needs to be replaced. They are now available on Ebay.
Oct 08, 2012 | Nikon D80 Digital Camera with 18-135mm...
I receive a Err on the display shutter snaps but no picture takes place. I have found out that if I try to take a pitcher let the shutter snap and then push the the apature botton i think it is on the...
Hi Jeff - The manual describes "Err" as a general error, a "Camera malfunction" and says "If error persists, consult with Nikon-authorized service representative." (Bottom of page 132 in the english version of the manual.)
Some folks have had mixed results with removing / mounting the lens once or twice, charging the battery and cleaning the contacts of both the lens and camera body's lens opening. More odten than not though - the camera has to go back to Nikon for repair. it appears that the shutter is replaced and things go back to working just fine again.
I would contact Nikon directly to learn if there are things they would like you to attempt before arranging for service of your D80.
I hope this helps and good luck. Please rate my reply. Thanks.
May 18, 2011 | Nikon D80 Digital Camera with 18-135mm...
Error message on D80 Nikon
To assist you we need more information than you provided. For the ERR message read page 132 in the D80 manual.
Apr 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
While my Nikon D80 is Error 09, can I update the firmware?
Have you e-mailed or called the techs at Nikon with your problem?
Jan 06, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err with f4 and r11 display
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Nov 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 shows err message. still after full reset it wont work
Check if your battery is charged. Are there any error messages? Otherwise, if your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
1. Turn off camera
Sep 17, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon DSL D80 with "r02" error
normally, just removing the lens and putting it again you solve the problem. F-- problem means "there's no lens attached !"
Mar 01, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
176 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
