Question about Maytag Legacy Series Top Load Washer
I need the manuals for both of my Maytag 3000 series front loading washer and dryer
4 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: Planning to purchase a pair of 3000 Series Maytag
These days, everyone offers front loading washers and dryers. The things to know about them, is that unlike the old style top loading washers (and even the very old type of front washers from 20+ years ago) is that they function much differently.
First off, remember that you should only use He (High Efficiency) detergent and that the amount you'll be using is much less as well, so you'll have to change your habit of pouring in too much, as it will cause you problems.
You'll also need to get used to the different noises, or lack of, when the washer is running. Except for the spin cycle, you'll hardly know its running. Now about the spin cycle, most front loading washers go into "turbo" mode and get going very fast, which is great since it leaves the clothes barely damp in most cases when you take them out.
Now for the not so good issues with front loading washers. You'll want to also change your wash day habits by doing starting your laundry washing with the cold water washing first and finishing with your whites or hot water washing as the last load you do. The reason for this is that front loaders tend to retain just a little bit of water in them when they're done, and by doing the hot water loads last, you give the washer the best opportunity to keep any odor forming bacteria the least chance to start with.
Another key thing that none of the front load washer makers tell you to do is, keep the door of the washer open slightly when you're done with your laundry, as the door gaskets will hold some water and that is part of where the moldy smells, that many people experience, comes from. We've found that by doing that little thing, along with an occaisional wiping out of the door bellows gasket, keeps our washer from having any nasty odors.
Some folks recommend using special tablets once a month (Whirl-out), but I have an adversion to doing a "load" without clothes and hot water, and an cleaning tablet - seems to me that kinda of defeats the whole "less energy-less cost" premise of efficient front loaders. So by leaving the door open, we've avoided all that and haven' had the odor problems at all.
OK, by now you're wondering when I'm going to give you something on the Maytags you wanted to know about! Almost any front loading washer will do a great job and provide you with a decent working life. I prefer the GE, Maytag, Whirlpool, Kenmore, etc., but really don't like the LG's. My reasoning is that the LG's seem to have more issues with torn door gaskets and error codes than the others. While the LG's look nice and most folks buy them because they're so darned pretty, they are a disappointment in where it really counts, in my opinion.
So buy any of the American made washer/dryer units mention and you'll be very pleased with them, and by the way, the Maytag 3000 series, do look pretty nice too!
Take time to read your manual with your new appliances and you'll be ahead of most folks and get the best performance out of them for years to come!
Hope you find this Very Helpful and best regards!
Posted on Oct 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: getting f21 error on my front loading 3000 series
F21 is too long to drain:: (more than 4 mins) Check your drain hose outflow into a couple of 5 gal buckets it should flow pretty fast. If not, there is both a suds sensor and the water level pressure switch that can be causing the problem. Since you do not have SUDS showing on your control panel I am assuming the suds sensor is fine. The water pressure switch itself can cause the problem even if you hear audible clicks when testing with an external hose. A clogged drain pump strainer can do the same thing. Lastly... the obvious... is the drain hose kinked???? Good luck and hope this helps.
Posted on Jan 11, 2010
SOURCE: We have a front loading 3000 series Maytag washer.
Just had this problem on Sunday. For a FRONT loading 3000 series, remove the front bottom panel (three screws - lay on floor and you can see them). There is a plastic can to the left of the pump. The front cover to this can screws on and off. Be prepared for water to gush out and unscrew the cover to the can. There is a filter/trap in there. Clean this out and it should solve the problem. Not sure why the manual does not cover this.
Posted on Jan 15, 2010
Maytag 3000 series front load washer has code F29. What does hat mean?
That error is a control board error. You might want to try unplugging the power for 5 minutes to see if it resets. If you using the pause cancel and start sequence don't work then you need to replace the control board.
Oct 04, 2014 | Maytag Washing Machines
Maytag Legacy Series Electric Dryer
May need a new timer, I had to replace mine, easy job if you watch the video online.
Jul 08, 2013 | Maytag Legacy Series Top Load Washer
Maytag 3000 series washer F21
Just cleaned out the drain inside the Maytag 3000 and boy if that don't fix it nothing will. I think something was growing in there. Seems to be working fine now. Thanks for the help
Feb 03, 2013 | Maytag EPIC MFW9700S Front Load Washer
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
Dear sir, We want to buy 02 nos of whirlpool make 8.5 kg washer 02 nos and one nos of dryer. We need the same for our factry on contineous operation so we want the best...
Hi and welcome to FixYa, I am Kelly.
I understand you want a whirlpool washer. What are you washing? It does make a difference on what would be recommended. The other question is does it have to be a front load machine or is a top loading washer ok?
Right off the top of my head for an 8.5 kg washer I would recommend the top loading MAT Series by Maytag (owned by Whirpool) These manual timer machines can take a beating and over loading only causes belt wear that is inexpensive and easy to replace. The only drawback is that the top loading machines use more water per cycle than a front loading machine. My thought is this... water is cheap... smaller front loading commercial machines used in continuous manner end up costing you more in repairs than you would pay for the water.
Product info: http://www.maytagcommerciallaundry.com/on_premiseslaundry/top_load_washers/commercial_energy_advantage__8482__top_load_washer_mat15mnaww.pro?scr=category
Once you see the linked pages select "on premises lanudry"
What I will tell you about commercial laundry machines is this. Keep the controls simple such as the MAT series. Maintenance parts are available on line and your down time will be minimal. The Maytags have the best warranty also.
As for the dryer Gas or electric? I am going to assume electric since you said "Factory"
For this I would recommend the MDE17 series Dryers, The dryers are 4 roller drum type dryers so the weight is carried equally front and rear of the drum so that the drum seals have a very long life.
I have been a Maytag repairman since 1970 and started in a family owned business. These recommendations are from years of experience. You may pay more up front on the initial purchase but over the years the continued in service time and minimal maintenance required make these units extremely cost effective. If I were to start my own business with 8.5 Kg per cycle washing requirements The MAT Washers and MDE Dryers Maytags are exactly what I would use.
Remember Maytag was purchased by Whirlpool years ago.
All Maytag parts can be obtained through Whirlpool.
I do wish you the best, Thanks for choosing FixYa,
Kelly
Dec 12, 2010 | Whirlpool Washing Machines
The bellow or door boot looks warped on my Maytag 3000 series front load washer. The washer is less than 2 years old and I just noticed the bellow looks twisted or warped, but it is not disconnected or...
Check the clamp on the bellow to see if it has come loose and shifted. You may be able to adjust the bellow and clamp and tighten it. If you need the parts, here are the links to them.
Bellow
Clamp
Nov 29, 2010 | Maytag EPIC MFW9700S Front Load Washer
Planning to purchase a pair of 3000 Series Maytag Washer & Dryer. Is this a wise choice.
Oct 24, 2009 | Whirlpool WFW9400S
Just bought a Maytag 3000 washer and dryer and
Most likely the metal is aluminum or stainless and you should worry about rust unless you wash your clothes with salt-water (seawater. not gonna happen.)
If you're really concerned, I'd attempt to reach a maytag customer service person.
800-462-9824
To reach a real person press 0 at every option. Should take three times.
May 11, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Washing Machines Logo
133 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
