Question about Kenmore Washing Machines
Kenmore modek series 80 type 111 I have a belt stuck under the agitator> can't seem to remove -how can I remove the agitator and get underneath?
    President:
  • 1,554 Answers
Your steps:
type 111
Posted on Jul 07, 2010
Testimonial: "picture confirmed - exactly what need to be done"
  • Jahn27
    Jahn27 Jul 07, 2010
    Continued..
  • Jahn27
    Jahn27 Jul 07, 2010
    Continued..
Type 80 series 111 will not agitate good
Possible that the drive has to be checked, check the motor, check the voltage to the motor at the cycle. If not the program module is a suspect.
Check also for friction to the shaft and spindle
click on : Bearings
Jan 23, 2013 | Kenmore Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Want to remove the agitator to look for my lost diamond ring
If your ring was small enough to go through the holes in agitator, then there is a pump under the washer that has plastic and rubber parts that can be removed. Especially Kenmore which should have a rubber boot type looking thing under the pump. You can't miss it.
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
163 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
