Question about Canon Office Equipment & Supplies
Canon IR5000 and the finisher unit
I have a Canon IR5000 and the finisher unit appears to be the problem. When it is connected the the main copier it displays Fault E000584-0002, but when disconnected the copier works fine. Is there a ''cheap'' way of fixing this fault?
Thanks,
  • 62 Answers
Dirty sensor inside finisher, blow whole thing out with air. Sensors look like small black c-shaped with connector with three to four wires. Dust dirt block when not supposed to be blocked. Shutter open sensor does not turn on when the #2 feed motor has been rotated CCW for 1 second.
Posted on Jul 07, 2010
Error code e000733 0001
its a communication error check the following on the ir5000 disconnect the finisher,disconnect the add and the paper deck (i.e. all accessories and turn the copier on
everything should be ok and when you press the system monitor button under consumables you should see the pic of the copier and only the copier
now turn the copier off and connect one accessory and see if it shows up
when you connect the last accessory and the problem is gone that means one of the connection was not good
hope that helps
if you connect one accessory and the code shows up then that is what the problem is
Oct 30, 2013 | Canon imageRUNNER 5000 Copier
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
Whether Canon IR5000 printer can be a tool, through the com settings (data). how do I to connect the cable to the machine copies com IR5000.butuh lan similar devices or other connector?
If I understand what you are ask???? You need to know where the ethernet cable goes in to the copier?? The conector is above the main power switch on the right side of the copier.... The print funcation is a option with a IR-5000...... Do you have a ether net PCB installed???? If you do not, you need to get a new boot rom & more ram & the ether port and lastly, you need to have your hard drive flashed to print...... Good Luck
May 18, 2011 | Canon imageRUNNER 5000 Copier
What is E000584-0001
M8 ( 2nd feed moter) or MS4 (limit sensor) is bad. Unless you know how to trouble shoot this finisher. There is no quick fix I could help you with.
May 12, 2010 | Canon imageRUNNER 5000 Copier
I have an old IR5000 and I woudl like to know when did they recall the part for heat image unit which stop the machine working properly.
On my knowledge parts for ir5000 is still in circulations.Especially the fixing rollers and gears, web,... atleast for EU
Apr 08, 2010 | Canon imageRUNNER 5000 Copier
Error Code 00532-0002 (Canon Copier IR5000)
The problem is in the stapler unit which is in the sorter unit. If you are tech savey then pull it out and removed all of the bent staples.
Dec 15, 2009 | Canon Office Equipment & Supplies
Error code E000020-0000 in cannon ir5000/6000
Main cause: The machine is not receiving toner properly because 1)The hopper connector is left disconnected. 2) The hopper motor (M9/M10) is faulty.3) The toner sensor (TS1/TS2) is faulty. 4) The DC controller PCB is faulty.
If you recently added toner, recheck that area.
Basically the copier is trying to add toner and is not getting it.
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Hardisk ir5000/ir5000i
You need to have the hard drive "Flashed" with the correct software. They come from Canon blank, you need to find a tech to flash the HD for you. If your question is if one would work in the other copier, the aswer is yes, but you need to have the printting software on that HD if you want it to print.... Good Luck.... Just for your info. you may want to ask your question in English if you want a respones from one of the techs.
Dec 30, 2008 | Canon imageRUNNER 5000 Copier
IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Dec 23, 2008 | Canon imageRUNNER 8500 Copier
367 people viewed this question
old marine
old marine
