Question about Brother HL-2070N Laser Printer
Grey background and dark streaks
Do i need a new drum or just a new fuse? when i print there are darker streaks all over the paper and a pretty sold grey covering the page.
  • Anonymous Apr 27, 2008
    I HAVE VERTICAL BLACK STREAKS ALONG THE LEFT SIDE OF PAGE. I'VE TRIED SHAKING THE TONER CARTRIDGE AND CLEARING THE STRIP. NOT HELPING
  • 89 Answers
Change out the toner first and then the drum. Also be sure there is not excess toner underneath where the toner is installed. If so clean that out with a dry cloth.
Posted on May 29, 2008
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Paper not clean when printing/copying How do I
first the paper can be dirty in a lot of ways...
i.e.
If you have dark "background"or small black dots, the problem is in developer and it need's to be replaced, or cleaning blade or drum.
If you have streaks on copy, the problem can be in drum and cleaning blade or fixing roller.
If the copy is too light, the problem can be in dirty optics or bad transfer corona.
There can be a lot of things... better call service for preventive maintenace, they will change all that is needed according the number of copies that machine has.
Hope that helps!
Sep 01, 2011 | Toshiba E-Studio167 Copier
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
My brother DPC 1000 is printing a dark background when copying. I have adjusted the contrast and nothing changes.
one of two things, either your drum is bad or your fuser.
one thing you can do to narrow it down, is make a copy and as the paper goes in almost all the way open the door. and take out the drum. some paper should be sticking out past the drum, if you still see the dark background, its probably your drum.
be careful, the toner has not been fused yet.
also, try cleaning the charge wiper by moving the tab left and right
Jun 25, 2009 | Brother DCP 1000 All-In-One Laser Printer
Brother 1440 laser printer. Started printing with
may some dust in corona ware or drum clean the drum.
Apr 06, 2009 | Brother HL 1440 Laser Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
Brother HL-2070N Laser Printer Logo
1,143 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
