Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Akai tv psp4294
Trying to find speaker wire for my akai tv. The speaker wires have a unique terminal on the end that plugs into the tv can someone tell me where i might find one.
SOURCE: Akai LCT2716 Flat Panel TV
Mine started doing the same thing.
I turn power off (pull Plug) for a few seconds then try again.
Works OK but must perform unplug procedure each time.
Posted on Mar 01, 2008
  • 54 Answers
SOURCE: akai tv-whats their phone number!!!??
International Headquarters
Akai Sales Pte Ltd
8 Commonwealth Lane
The Grande Building
Singapore 149555
Tel : (65) 6476 6686
Fax : (65) 6479 9832
visit page here : http://www.akai.com/contact.asp
Posted on Aug 18, 2008
phone them in the USA
(216)454-0865
or
(818)227-1695
Posted on Sep 08, 2008
  • 367 Answers
SOURCE: Akai LCT2785TA troubleshooting
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Apr 06, 2009
  • 12 Answers
SOURCE: AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Posted on Sep 06, 2009
AKAI SOUNDBAR CRACKLES WHEN I CONNECT TO EARPHONE SOCKET ON jvc tv
Loose connection.
Either the jack on the TV, the plug on the line or the wire itself is beginning to break inside the casing.
You may have to open the Soundbar and replace the wire.
Jan 08, 2015 | Akai Televison & Video
How do I connect speakers to an AKAI GXC-725D cassette player?
manual looks like its available here. you have to register but its free
http://www.hifiengine.com/manual_library/akai/gxc-725d.shtml
Dec 12, 2014 | Akai Car Audio & Video
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
If I'm not mistaken, that model only has a VGA input. Unfortunately, you are stuck using composite, component, svideo, or VGA video inputs.
Feb 08, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No sound
The speakers on these are usually at the bottom and do come off the set. If they are on the TV make sure there are wires connecting the speakers to the back of the TV at the speaker terminals.
Dec 28, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
External speaker hook-up
Ok, after A LOT of internet research I could not find any solution. So I decided to do a "chop suey" connection.
Went to Radio Shack and bought ...
Insulated Grip 2-1/4"Alligator Clips w/screw terminals 10 (five red & five black)
(A smaller alligator clip can be used if you have a soldering iron to connect the wires.)
30-Ft. 18-Gauge Clear 2-Conductor Speaker Wire
It cost about $15 for everything. Be sure to have electrical tape as well.
Stripped speaker wires to fit through each alligator clip and twisted it around the screw terminals of clip. Tapped screw terminal to cover wiring. Do this for 2 black and 2 red clips.
To install l laid the TV on its back and insterted each alligator clip to firmly fit on each terminal. Because the clips are large it will be a tight next to each other. Be sure to test one line and speaker first before completed the second line and speaker.
GOOD LUCK!
Nov 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai tv-whats their phone number!!!??
Akai Sales Pte Ltd
8 Commonwealth Lane
The Grande Building
Singapore 149555
Aug 18, 2008 | Akai LCT3285TA 32 in. LCD Television
Sound quality - Akai LCT2701TD
I don't have any problem with sound when I plug my cable wire directly into the TV's coaxial port. It sounds like there is a problem with the speakers or the sound board in the TV. I don't think the cable box would even help. If the TV is still under warranty, maybe you could borrow a cable box from someone else to see if it will work, and if it doesn't, contact Akai tech support again and demand repairs.
Jan 11, 2007 | Akai LCT2701TD Television
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
259 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
