Question about Insignia LCDTV26 26 in. Television
Insignia LCD HD tv with "No Signal/VGA input"
Subject says it all.
It was working fine last night.
I tried switching the modes so I could play a DVD which failed
and then I couldn't get the cable channels to come back.
Instead, all the screen says is
No Signal
VGA input.
Maybe it's obvious but I can't figure it out and I've tried everything I can think of.
HELP!
  • Steven May 11, 2010
    Hi willuns;
    Out of curiosity I took the plunge and looked for this elusive 'reset button'. Can't find one anywhere.. especially where you indicate there is one.
    Please have a look at the photos, maybe edit one (a circle or arrow) to include this buttons location is, and we''ll all give it another go!!
    Here's the photos:
    http://s191.photobucket.com/albums/z51/s...
  • Anonymous Mar 30, 2014
    My tv says "no signal" and when I press the input button it says analog 3.0 and will not change. I've unplugged and plugged back in everything, turned everything off and on again, tried to change the channel on the tv and the DVD player. The tv goes back to 3.0 in seconds and the snow never goes away. The TV suddenly went to analog and snow while I was watching a program. Help!
I am trying to locate the reset button and can not locate it.  What does it look like?  I took the back off the tv already, do not know if I have to take more apart.
Thanks
Posted on Jul 02, 2008
Your Television need to be reset. Take the back off carefully, locate your picture lamp, somewhere in that area should be your reset button. Your television needs to be powered on, so be very carefull not to touch anything other than the reset button, hold the button in until your TV goes blank, then release and put your cover back on. That's it, your TV should be back to normal. You might have to run your setup again.
Posted on Apr 18, 2008
How do i connect my pc to my tv
Used the VGA cable came with ur computer monitor,used that VGA cable plug in VGA input it the tv and plug it other end to the computer video card.Used ur tv remote look for a input button pushes look for the mode computer signal in the tv like input 1,2,3..so on.
Feb 12, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Insignia 26"LCD TV "No Signal"
Your description pretty much narrows it down to tuner failure. I have had experience with Insignia products so not surprised.
Mar 03, 2017 | Insignia LCDTV26 26 in. Television
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
The Insignia LCD tv shwos no signal?
Using the function button or source button on the remote switch to TV mode. that should do it.
Feb 23, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
With the model# and date of manufacture I, or others might be able to help better.
• Generally, Most of the insignia TV's are manufactured by Lucky Electronics and have some amount of problems on the main board. The power supply filter is likely drying out it's capacitors as they use caps that are to close in rating to their actual voltage. IE 25 volt caps in a 24.5 volt circuit.
(We replace them with 35 volt.)
This causes flakey actions. Try unplugging the set for an hour, and try it again. It may work, but for how long? IF it works, you should replace all the caps in the power supply area, about 10. You can be sure that one is bad if it is swelled up, dome shaped on top, or hot.
Apr 03, 2017 | Insignia 37" LCD Flat-Panel HDTV
Hitachi 26LD6600 no signal coming up
You have to switch the Television to the correct input line. This can be done by pressing an Input, or AV of function button on the television remote control.
Nov 08, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Insignia LCDTV26 26 in. Television Logo
3,373 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
