Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Need to remove front drawer panel
How do I remove front drawer panel of a Fisher Paykel DS602 dishdrawer?
  • Fisher and P... Master
  • 3,247 Answers
There are two plastic bolts on each side of the dishwasher drawer holding the front cover. Get a plier to pull these out but make sure the cover is supported so that it does not fall down.
see installation manual page 7. The location of the plastic screws is shown in insert diagram of notation 6. This is for a later model but yours should be similar.
Hope this helps. Wonder why you want to remove the front cover?
Posted on Jul 08, 2010
  • I found using long nose plters works best and you will need to turn and pull them out. Now lift th cover upwards and out at the bottom.
  • Sorry I continue)You can know pull the earth wire of before going much forther . Normally a green and gold wire . It should pull off easily . now you have removed it and the panal is on an angle with the bottom sticking out pull down gently to remove , taking not of where the hige pin went through and where the hook like tabs slid into or outoff , because they ara tricky to put back on sometimes, as sometimes they spread widder especialy the stainless in wards an
Fisher paykel dishwasher
If the panel display on the lower drawer is lit and you can select the program then most likely the water inlet valve is fault and needs replacement. But if the panel is dark and none of the buttons operate then the power to the drawer is cut off. This can be due to a number of reasons including the power board at the base loosing one power circuit or the thermal fuse in the drawer is blown. Please provide model number of dishdrawer unit and also please describe what is actually happening.
Jul 30, 2014 | Fisher and Paykel Dishwashers
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
F2 error code drawer
In order to find the availability of spare parts for your model of dishwasher it would be helpful if you can provide the Product Code from the label on the front of the main unit.
May 23, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
What does error F1 mean and is it expensive to fix
Hello there
The f-1 error is comng from the fflood switch meaning it is not recognizng the level of the water in the machine
First thing you need to do is pull the front panel off the drawer, :
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, pull the wire harness connectors off the main control board (lower right-hand side) to inspect for junk and debris
If nothing is found
The next step to remove the botton drawer from the unit so so you can inspect the switch itself
In order to do this, You had to remove the wire harness cover on the underside of the drawer.
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
TAKE NOTE OF the positions of the wires on the flood switch and removing them, unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, ohm out both switches and ENSURE THEY CHECK OUT GOOD OR HAVE SOMEBODY DO THIS FOR YOU inspect the contacts and SEE IF they look oxidized or detereorated , evidenced by discoloration.
If it does look discolored clean the contacts as needed now plug in everything as it was originally and put in the drawers than run it to see if it does reappear if not you saved yourself about $300 dollars on having a tech come and do this ok
Nov 23, 2010 | Fisher and Paykel 23 in. DD603H SS...
F1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
May 15, 2010 | Dishwashers
Please tell me where to find float swich in fisher and paykel dishwasher
is this dishwasher a dishdrawer unit or is it a freestanding unit. if it is a freestanding unit it has a pressure switch. if it is a dishdrawer it relies on how many amps it takes to turn pump. hope this helps. what is the problem with your unit? please reply 4 more help.
May 03, 2010 | Fisher and Paykel DS602 Dishwasher
Change Fuse on Fisher Paykel Dishdrawer
I have a single drawer F&P dishwasher. This morning a safety switch trigged. This afternoon when I went to use the dishwasher found that it had no power. There are no lights and there was a smell of something burning. The power outlet has power. Can you help?
Feb 08, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher not draining well
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Comment posted on Feb 07, 2009 there should be tabs on the sides of the drawers at the sliders near the front of the machine.
Feb 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
546 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
