Gateway ma7 will not boot up. Tried to restore it with a disc but then it says the hard drive is non existant-would there be another issue?
Is your restore disc the MS OS disc?are you trying to fresh install OS? if so then you need a restore/ OS disc with SATA drivers in it...then it will 'see/recognise' your HDD
Posted on Dec 02, 2010
Gateway ma7 MT6832b
Have you run tests on the hard drive and/or system board? Wallpaper can use a lot of memory, have you checked how much memory is free when running your usual group of tasks?
Feb 07, 2014 | Computers & Internet
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
Will not boot...only blank screen with blinking cursor. how do I fix it
You have hard drive issues or windows files are corrupted, remove hardware and reseat it back in place, sometimes this will get the hard drive working, if this fails! set the boot order to DVD CD and try and run the recovery disc, if no change! it means the hard drive has issues and may have to be replaced.
Mar 05, 2012 | Gateway nv Computers & Internet
I have problem with my hard drive, my laptop is a Gateway MA7 I when I turned up it appared a blue screen cheking disk but after this It can't turn on.
power up your laptop from scratch start hitting F8 until an alternate boot screen come up.select boot in safe mode. Once you have booted up restore your system back to a good work date?
Feb 23, 2011 | Computers & Internet
I receive a no operation system message while booting
Buy a new hard disk drive! Use the 2 golden Gateway, Applications, Drivers, & Operating System disc, also known as Restoration DVD to reinstall your Gateway programs & operating system. After that, reinstall your backups.
How much disk space do you need? Why buy a 320 GB HDD if you only use 4 GB? So, keep the bytes down if you don't need them and that will keep the costs down, too!
The Gateway support discs can be had at: www.Gateway.com/Support .
~PC-Doctor
Nov 12, 2010 | Gateway (M520HD80G) Hard Drive
Gateway 4530gz blue screens
Sounds to me like the hard drive is defective. If you are able go to the manufacturer's website of the hard drive and download and burn out their hard drive testing utility. Boot from the disc and test the hard drive. If it passes then download Memtest (free) and burn it out and boot from it and test memory. Likely one or the other is the issue
Jun 29, 2009 | Gateway 4530GZ Notebook
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
CANT BOOT FOR REINSTALLATION OF XP, IT SEZ "NTLDR" IS MISSING, ALSO MENTIONS SOMETHING ABOUT THE HARD DRIVE NOT WORKING
If you have the OS disks try a repair first. Run the OS disk and choose the repair option rather than reformatting. That usually fixes ntldr issues.
Apr 30, 2009 | Computers & Internet
System error
That is an operating system error or glitch. You will need to run a repair with the recovery or operating system disc. At start up, press F12 to go to the boot menu, and with the disc in the drive, boot from the CD drive. Then follow the directions. You're going to want to do the repair from the second repair section, after it finds existing operating systems, not the first repair using the recovery console. If the repair doesn't take, then using the same process, you need to delete the existing operating system, reformat the hard drive and install a new operating system. If the hard drive won't format, or if you have any issues during or after the install, then the hard drive has failed and will need replaced.
Aug 23, 2008 | Dell Latitude D505 Notebook
Need System Restore Disk/Software
the system disk are usually on a partition on the hard drive.
if you didnt make a copy of the HARD drive or made a cd from the images on the hard drive, gateway wont help.
you could buy a cd from them
some gateway have a special boot directory to boot from
try looking for that.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 18, 2008 | Computers & Internet
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
