Question about Philips 32PF7320A 32 in. LCD Television
Tv takes 1/2 an hour for picture to appear
Can you tell me why my tv takes around 1/2 hour for the picture to appear on the screen. I can get sound but no vision. Tv is about 5 yrs old
  • 11,361 Answers
It can be that the 24vdc supply is dying due to bad DC filter caps, that will be the fist place to look, if he 24vdc is OK, then the next part to look will be the backligh inverter board, verufy hat it does have 24vdc and the 'BL ON' (Backligh On) signal is present.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 07, 2010
My LOEWE TV has an intermittent fault. Sometimes when you turn it on the sound is there, but no picture. Other times it takes ages for the picture to eventually appear. Other times there is no sound or...
Yes,this tv it is repairable,ur tv it is having a problems with a 1 or 2 long boards that are call the LCD inverter boards.These 1 or 2 long LCD inverter boards only job it is to provide the LCD screen panel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD invert boards for the replacement.
Apr 08, 2011 | Televison & Video
The screen stays black after the power is on, but the sound works.
In LCD TV, is normally that the picture appear after sound, tipically around 60 seconds, but in some cases take up to 3 minutes, for your security, please check your owner manual
May 19, 2010 | Element Electronics FLX3210 32 in. LCD TV
My 27inch westinghouse flat screen has sound but
Ur LCD inverter board is dead.Replaced this LCD inverter board u will get ur picture back.This a simple repair take ur tv aparts,take out the LCD inverter board,it a long shape of a board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replament.U will get ur picture back.Ok,good luck,labors about an hour work.
May 08, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
Sony Trinitron TV now taking around 5 minutes for picture to appear (sound comes on instantly) Is it worth repair or should I cut losses and replace set?
How old is the TV?
Sony Trinitron sounds like it may be from the 1980's?
Some TV engineers can use a piece of equipment to do a "tube boost" but this is sometimes risky and can completely ruin the tube, but it's a risk you would have to take.
If the TV is over 15 years old, and has been used regularly, (like 4 hours every day or more) it seems likely that the tube has reached the end of life.
TV cathode ray tubes are like light bulbs...they do not last forever!
Nov 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
No picture or sound
If the screen displays VIDEO 1 then the set is in video 1 mode, looking for a signal on the video 1 input jacks. Press the TV/VIDEO button on the remote (or the set itself if it has it) and cycle around to the input you are actually using.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Sanyo TV model DS25710 or DS25730
Set has a bad vertical sweep IC. Also This Sanyo has a tendancy , when the IC blows out , to take the fusable resistor in the sweeo supply that feeds the vertical IC. This set should only be serviced by a trained technician because of ther high Voltage that lingers within. This repair should run you antwhere from 85.00 to 150 bucks. Good Luck
Jul 31, 2006 | Sanyo DS24205 24" TV
Picture disappearance & tv turns off
It sure sounds like you have a classic case of bad solder joints. Resolder all the connections on all boards.
May 31, 2006 | Toshiba 36A43 36" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Philips 32PF7320A 32 in. LCD Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
