Question about Whirlpool Duet GHW9150P Front Load Washer
My control locked light is on & will not turn off. I have unplugged it hoping that would solve it but, no. Sooo now I can't wash my clothes.
  • 5,911 Answers
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This feature can often be set unintentionally and usually is not an indication of an actual problem with the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on Jul 07, 2010
How do I turn off the control lock on a whirlpool duet washer?
To unlock the controls select and hold END OF CYCLE SIGNAL for 3 seconds untill Control Locked status light turns off
Sep 12, 2014 | Whirlpool Washing Machines
Light stuck on lock and wash
CHELL TRY TO DO A WASH WITH OUT CLOTHES,AND DO A SHORT PROGRAMM.
Jan 20, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Control lock light
Press and hold the DRAIN & SPIN button until the Control Locked light goes out. You will likely have to hold this button at least 3 deliberate seconds, maybe as long as 10 seconds to disable the control lock.
May 28, 2010 | Kenmore Elite 45986 Front Load Washer
Control locked light is on
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on.
The procedure for clearing this is to press and hold the "end of cycle" button for three seconds. It should be all the way on the right of the panel. Let's try this first. before we look at anything else. Hope this helps and let me know what happened. Good luck.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Control Locked
push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
Hold the "end of cycle signal" button down till its unlocked. Let me know :-)
Sep 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
170 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
