Question about Milwaukee Tool Case Heat Gun
Need to find the fuse case/panel and wiring diagram for 480E Case backhoe/loader. Trying to chase down a problem with the flood lights.
2 Suggested Answers
  • 332 Answers
SOURCE: can't find hydraulic oil filter on my case 680e
Should be located, from the seat, on the right hand side just in front of the cab/ ROP frame
Easy to tell due to the 1.5" hoses going to it
Hope this helps
Posted on Apr 04, 2010
Specs on head bolts and order to torque sequence for a 580d case backhoe
http://www.ioffer.com/i/case-580d-loader-backhoe-service-manual-580-d-bonus-162592324
Jun 05, 2015 | Cars & Trucks
Can't release the bucket on my 06 case 420 series 3 skidsteer. It works electronicly somehow.
You're going to have to find the wire that goes to that actuator and put power to it, possibly a bad fuse is causing this. We don't have to remove the bucket very often and this electric cylinder can get bound up with corrosion and pop the fuse. I just removed the electric cylinder from my skid loader that locks my system so I can release it manually. But then I don't know that there is a manual lever on your unit, mines an '86 vintage Toyota skidsteer that I built from 3 I had and rebuilt the 2J diesel engine. It works beautifully. I just love it. My only Case is a '72 Backhoe I rebuilt.
Apr 22, 2011 | AMC Wrangler Cars & Trucks
99 ford contour A/C fuse burnt in socket...need to find the 2 wires to bypass with inline fuse, driver side fuse panel? help?
Somthing doesnt sound right here, someone must of installed a bigger fuse than whats called for, i would have the system checked to see why its drawing so much amperage, you will need to remove the fusebox and chase that wire, you want the ac side of the wire not the hot side, if you are reusing the power wire then okay chase them both, but you will need to chase them into box, use an ohm meter with a continuty test on it to locate the right wires,okay i just found a wiring diagram, the fuse is on the driverside fuse box , okay the wire you are looking for is violet/purple and this is for fuse location #37 which holds a 30amp fuse,the other wire is a power wire and should be red,note there are a lot of hot red wire so try to use the same one by chasing it.
Mar 23, 2011 | 1999 Ford Contour
No parking lights.. Head lights and brake lights work. No power getting to parking light bulbs. All fuses in panel test good. Need good wiring diagram to chase wires. Any suggestions on problem or where...
You can try an internet search for the wiring diagram. No power to all the parking lights? Then probably the light switch. Make sure you have power to both sides of the fuse. If not the either wiring from the switch or the switch itself. Good luck.
Aug 16, 2010 | 1982 Chevrolet El Camino
Case 580C Backhoe starting problems
either you have a short in the wiring, a loose connection somewhere or a bad starter, check for broken wires first and clean connections. then try the starter see if it turns with a direct connection to another battery
Jul 14, 2009 | Champion International Garden
1990 Toyota SR5 V6 ext cab, climate control lights do not work
if you have a manual or a trouble shooting book, locate the wiring diagram for the headlights, sometimes there is an in-line fuse or relay located on the vehicle somewhere. there has to be a fuse somewhere i promise. start from the headlights, try to chase back until you get under the dash. normally the wiring will be bunched up into a (compact type) or bundel, worse case senerio, split open bundel to expose all the wiring. there is sight that may help you. autozone znet.com
Dec 26, 2008 | 1990 Toyota Pickup
Milwaukee Tool Case Heat Gun Logo
314 people viewed this question
Top Milwaukee Tool Air Tools & Compressors Experts
John Trevino
Geert Deschamps
Are you a Milwaukee Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
