Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Frost and ice build up ice maker
Frost and ice build up on ice maker shute and outside ice bend ????
catriver
  • 878 Answers
SOURCE: Frost on Ice Maker shute
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. Catriver..post back.
Posted on Oct 21, 2006
gaeb7
  • 25 Answers
SOURCE: Frost build up in the freezer section of my side by side Kenmore
Replace the defrost clock.
Posted on Feb 25, 2009
  • 145 Answers
SOURCE: frost build up in freezer (ice maker section)
Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
the is a easy way to adjust that but you are going to have to take
your ice maker out
then using a flat head screw driver remove the white square cover
you will see a gear and a adjustment screw and a lever like this
( - I + )
turn the screw to the minus sing a quarter way and install the ice maker back up.
Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
the ice maker feel up buy time not buy water level.
Posted on Jun 28, 2009
aasc
  • 1606 Answers
SOURCE: frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Posted on Oct 02, 2009
  • 112 Answers
SOURCE: shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Posted on Oct 29, 2009
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
Frost builds up on outside of ice maker
The little door that opens and lets the ice fall into Your cup is not closing all the way, allowing cold air to escape from Your Freezer and causing frost to build up. Simply look up at it or open the Freezer door and place a lit flashlight in the ice chute so You can see where the light is shining through the ice dispenser at. There should be a build-up of ice there that is keeping the "trap door" from closing all the way. Clean that off and You should be as good as new.
Aug 19, 2014 | Kenmore Side by Side Refrigerator
Bottom of ice maker is frosted up & leads to food getting frost
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
Aug 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost build up around ice maker. where the ice comes out.
With this information , it sounds like the flap that lets the ice thru the door , is not closing completely , letting the fan in freezer , pull in the outside air .
Jul 25, 2009 | Kenmore 53542 / 53544 Side by Side...
Icing and frost clogs the ice dispenser
check the dispensing flapper ,, it may not be shuting there is a spring and lever it the lever is bend or if the spring is broken it will not close correctly clean and clear all the ice .. then check that it will close after you open it...hope it helps
Sep 07, 2008 | KitchenAid Superba KSCS23IN Side by Side...
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
411 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
