Question about Seagate Barracuda 7200.10 320 GB SATA Hard Drive
I have a barracuda 7200.10 320 Gbytes. The power/USB failed so the unit did not start up. I bought another Seagate and plugged the failed drive in but nothing happens? The new unit has a slow flashing light when no drive plugged in and a fast flashing light when the broken drive is plugged in.
motaro
  • 449 Answers
SOURCE: My seagate barracuda 7200 b will not boot up. It has been operating fine for the last 8 months
i suggested you use NORTON DISK DIAGNOSTICS to repair the MBR(master boot record)the master boot record is bad and you can use winXP bootable nto repair the drive by pressing R after booting is completed.but you need to be able to use DOS prompt before you can do this
Posted on Feb 06, 2008
  • 29 Answers
SOURCE: My seagate external drive is not working correctly
sir,maybe your drive has the bed tracks or bedsectors or smart is damaged,so when do u get the hdd?
You can try to know more hdd knowledge from www.salvationdata.com,there is many iformation for the hdd problems
Posted on May 05, 2009
romsky79
  • 822 Answers
SOURCE: seagate barracuda 722.10 light flashing but hard
actually im fixing hardisk drive if you change the board it will work and spin. but the problem there is a serial protection of your disk and you cannot retrieve your files. now you have to troubleshoot the board. check fuse protect, rectifier diodes for 12v&5volts, and regulator.
Posted on Jun 10, 2009
  • 699 Answers
SOURCE: seagate barracuda external 500 gb hard drive usb
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Posted on Jan 05, 2010
bronk50
  • 27725 Answers
SOURCE: i need the driver of
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
Posted on Nov 24, 2010
Interface seagate barracuda 7200.7 200GB drive sata to usb 2 forum
Hello. You are correct that there are no jumpers, however, when you connected the SATA cable to the Internal hard drive, did you notice there were two similar connectors. One was for the SATA the other, longer one is for the POWER for the drive. If your SATA to USB has both connectors make sure they are both installed properly. Be careful you don't break those little plastic tabs because they are not warrantied. If the drive does have power and spins up then it may not be initialized (formatted) and will need to be initialized using START, Administrative Tools, Computer Management, Disk Management. or just click on start and type diskmgmt.msc in the RUN box.
Hope this helps..
Nov 04, 2012 | Seagate Barracuda 7200.7 200 GB Hard Drive
I have the seagate barracuda 7200.7 200 gbytes whats the part on the outside that the master belt cable hooks in to a circuit board can i change that my kid took it apart not the insides of the harddrive...
You will need to get another circuit board from another Seagate Barracuda 7200.7 200GB Hard drive. Either ask your local computer shop or check local ads for sale. Like Gumtree or Ebay or the like.
A hard drive recovery centre may have this particular circuit board as they will use it to transfer your information from your current hard drive to a new hard drive. This may be another option available to you.
Take care!
damnor01
May 23, 2011 | Seagate Barracuda 7200.7 200 GB Hard Drive
I have a Barracuda 7200.7, 80 Gbytes, Model ST380011A hard drive. Today when I turned on my PC, it just didn't show up! I disconnected it and connected again. Still the same problem. I had 4 partitions...
yes it is. try to plug in another drive that drive to be main and yours second drive make sure that the first drive has a system on it first then copy all files that you need off it ok jim.
May 15, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Is Seagate Barracuda 7200.7 80 Gbytes a Sata Hard Drive or not?
Hello and Welcome to FixYa!
Yes this series of Seagate is SATA.
Concerned, Nooh.
Feb 17, 2011 | Seagate Barracuda 72007 SATA 80 GB SATA...
I need the driver of my Seagate Barracuda 7200.7 80 Gbytes Ultra ATA Model: ST380011A Thanks
hope this helps
Nov 24, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hard disk Not Detecting (Media Problem)
may be comming steps you solve your problem
check your bios settings on first bootable devices
check your ide or sata cable interfacing mother board correctly
check the power connections
also you want check this one is your os faulty,now you make master &sleve and boot anther hard drive
Jun 12, 2009 | Kanguru - 500GB Disk (Black)...
I have a barracuda 7200.7 80 Gbytes. The dirve spins but stopped booting. Started making clicking noises. I smacked it a bit a few times. Now, the system doesn't recognize the drive in BIOS at all. I...
this hard drive is toast and sadly you are half the reason as you never, ever ever open or hit a hard drive.  There are data recovery firms however, they are very expensive.
Nov 27, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Jan 14, 2008 | Computers & Internet
Seagate Barracuda 7200.10 320 GB SATA Hard Drive Logo
357 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
