Where may I purchase a Cassette Daisy Wheel for a Brother Electronic Typewriter?
  • 42 Answers
Westcoastplaten.com
They are typewriter parts specialists
Posted on Apr 29, 2008
How i can shift to arabic
You have to buy an Arabic printwheel and install it.
To insert the daisywheel:
1. Open the top cover.
2. Pull the lever toward you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear" on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its original position to lock the cassette daisy wheel into place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press and hold the CODE key. While holding CODE press the Q key, this will move the carrier to the previous position.
Sep 11, 2013 | Brother SX-4000 Typewriter
The key I push is not the letter that prints
Many factors affect correct character selection. To isolate the problem, follow the directions below:
  1. Is the daisy wheel locked into the carriage correctly?
    1. Open the top, locate the black lever near the hammer and move it away from the platen.
  1. Lift out the daisy wheel. Inspect the petals to see if they may be damaged.
  1. Locate the small spring loaded pin near the center of the daisy wheel hub. If the pin is missing or sticking, or the daisy wheel has damaged petals, replace the daisy wheel.
    1. Look into the opening from where you removed the daisy wheel. Ensure that there is no debris in the area; use canned air to blow out the area.
  1. Reinstall the daisy wheel or install a new one if the old one is damaged.
  1. Remember to push the black lever towards the platen until it snaps into place.
  1. Close the top cover and turn on the typewriter.
    1. After the carriage moves to the left margin, insert paper, and open the top cover.
    2. Push the hammer forward until it presses the daisy wheel petal onto the paper.
    3. It will leave an impression on the paper; it should be a lower case "h".
    4. If the impression is any other letter than those above, the typewriter may require service.
  2. Examine the keyboard area. If there is any contamination, i.e. spills, pet hair, etc, the keyboard may need to be cleaned by a trained technician.
  3. If the problem is not resolved after these actions, the typewriter may require service.
Brother typewriters have a 90 day labor, 1 year parts limited warranty. For 90 days from the date of purchase, Brother International, or its Authorized Service Centers, will repair this product free of charge if defective in material or workmanship. After 90 days, and until one year from date of purchase, Brother will furnish, free of charge, a replacement part for the defective part of this product, you pay for labor.
If your machine is within Warranty, you can contact Brother Customer Support Center at (1-877-276-8437)
Apr 05, 2013 | Brother GX-6750 Electronic Typewriter
How do i set a new daisy wheel for the ML 100
2. Pull the lever towards you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right.
5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly.
7. Press [CODE]+[RESET] to move the carrier to the previous position.
(make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right.
improper insertion of the daisy wheel may cause malfunction and incorrect printing.
It is not necessary to remove the cassette ribbon when replacing the daisy wheel.
Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
Dec 22, 2010 | Brother ML-100 Typewriter
Please send instructions to install a replacement daisy wheel on a brother GX6750 typewriter
All you have to do is lift up the lid over the top of the printer. Make sure the machine is turned off. Remove the ribbon cassette. There will be a lever either on the left or right on top of the printer. Gently pull this toward you and the assembly holding the daisy wheel will drop toward you. The daisy wheel is is a transparent plastic case. Hold the tab and lift up the wheel. To insert the replacement is the reverse of what you have just done
Oct 13, 2009 | Brother GX-6750 Typewriter
When i turn it on it says check printer and its beepin
You do'nt say what make. Turn the machine off. Check the daisy wheel is in correctly, check the ribbon cassette is in correctly, and check the lift off tape is not tangled in the daisy wheel.
Oct 13, 2009 | Brother EM-430 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
BROTHER GX-6750 TYPEWRITER
change CASSETTE DAISY WHEEL,
Jun 24, 2009 | Brother GX-6750 Typewriter
How to fit a daisy wheel to a type writer
This is primarily for the Brother typewriter I don’t know Olympia typewriters. Brother print wheel are contained in a plastic “cassette” and are not that hard to install.
Oct 04, 2007 | Office Equipment & Supplies
jasbo
jasbo
