Question about Canon ImageRunner 1600 Copier
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image writer 2000
  • 1,219 Answers
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Posted on Jul 08, 2010
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
Paper jammed open left cover
Hello, To solve this problem try follow this steps
1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays, inspect them for wrinkled or damage paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly
The goal is to keep the paper from tearing. If several pieces are jammed together,try pulling out the middle piece first to loosen the jam.
7. If the paper does tear, try rotating the roller gears manually to free the paper.
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Jun 29, 2011 | Office Equipment & Supplies
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
When the cartridges move to the right there is a hang up of some sort and then error 5100 comes up
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink ink.
  • 1
    Check the paper feed tray on the front end of the printer to see if there is any paper visibly stuck inside the printer.
  • 2
    Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • 3
    Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • 4
    Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • 5
    Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
  • 6
    Repeat the process with the other ink tanks, and then close the printer's cover. Power the printer off and then back on again.
  • Feb 01, 2011 | Canon PIXMA MX310 All-In-One Printer
    How to fix error code 5100 for canon ip6320D. it appearing while head cleaning.
    This is either due to a physical error caused by a paper jam, or incorrectly seated ink. To fix:
    Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
    Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
    Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
    Jan 21, 2011 | Canon Office Equipment & Supplies
    My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
    Clear the jammed paper as follows.
    Observe Cautions signs in printer.
    Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
    1. Press the cover release button and then open the front cover.
    2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
    3. Pull the paper tray completely out of the printer.
    4. Close the front cover.
    5. Pull the jammed paper up and out of the printer.
    6. Open the front cover again.
    7. Open the back cover.
    8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
    9. Using both hands, gently pull the jammed paper out of the fuser unit.
    10. Close the back cover.
    11. Pull the duplex tray completely out of the printer.
    12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
    13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
    15. Put the drum unit and toner cartridge assembly back in the printer.
    16. Put the paper tray firmly back in the printer.
    17. Close the front cover.
    18. Make sure that the Paper LED is now off and the printer is ready.
    After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
    Dec 04, 2009 | Brother Office Equipment & Supplies
    My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
    give this a try
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    Paper jam
    alternative :
    Mar 23, 2009 | Sharp UX-B20 Plain Paper Inkjet Fax
    Epson c20ux -ink cartridges installation
    Power on
    Open door or front top of cover that covers cartridges.
    Systen should move ink carrage to center so you can take out old and put in new.
    Close door/cover and should get some data on Monitor to follow so system recognizes new cartridges.
    If no work u have some type of a problem in printer.
    I'm assuming you don't have a paper jam or anything. If you do must clear.
    Luck
    JC
    Jan 18, 2009 | Epson Stylus C20UX InkJet Printer
    Printing problem
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
    Check if the Encoder Strip is Broken or Missing
    1.Power down the printer and unplug the power.
    2.Slide the cartridge carrier inside the printer a couple of inches to the left.
    3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
    Note:
    The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
    Reposition the Encoder Strip
    1. Remove the power cord from the printer.
    2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
    3. Gently slide the ink cartridge carrier to the middle of the printer.
    4. Gently move the top part of the printer belt to the right.
    5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    8. Once the encoder strip has been re-seated, close the scanner lid.
    9. Re-connect the power cord to the printer.
    Ensure the Paper Tray is Not Overfilled
    Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
    Adjust the Printer Paper Guides
    Adjust the paper guides to fit the size paper being used .The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides.
    Locate and Remove Any Obstructions Inside the Printer and Input Tray
    1. Open the front cover and make sure the kickstand (if there is one) is engaged.
    2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
    3. Close the cover.
    4. Remove all paper from the input tray.
    5. Inspect the input tray for any obstructions.\
    6. Remove any visible obstructions.
    7. Reinsert the paper.
    Nov 22, 2007 | Dell 922 All-In-One InkJet Printer
    583 people viewed this question
    old marine
    old marine
