Question about Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx USB
How do i set a behringa 1832 fx mixer - Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx USB
I have a behringer 1832fx mixer and have the manual that illustrates how to set up for a band and/or other instruments etc! is this is what your asking for?
regards Col
Posted on Sep 06, 2010
How do i connect a monitor to the 1202FX mixer
Hi, you can use the Control Room outputs to give you an additional output with it's own level control but of you want a separate "mix" rather that overall level you could try the FX send & use the FX controls per channel to set the mix - depends how / if you are using the FX of course! - Else upgrade to a mixer with 2 Aux sends - use one for FX & the other for monitor :-) e.g. some of the Alesis do this! 'Good Luck!
Dec 21, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
I cant find the echo part on the mixer for karaoke
The effects or FX section is on the top right of the mixer. On your vocal channels find the yellow knob marked FX and turn it to 0. Choose the effect you need using the Program knob (top right) for karaoke this will probably be 03 or 06. Start singing and turn up the yellow knob marked 3 - FX under AUX Sends until the LEDs above them hit -0db, no higher.
Now find the button marked FX - Main Mix and make sure it is UP.
Turn up the yellow knob (3 - FX) next to it until you can hear enough echo on your mic.
Dec 09, 2011 | Behringer XENYX 2442FX Mixer
I have a mackie fx 8 mixer connected to two thump 15 " speakers. i want to add a set of base non- powered speakers with power amp to my fx 8. what are the connections?
Balanced audio interconnects (either XLR or TRS cables from the mixer and then balanced audio interconnects from the amp daisy chain inputs to the existing speaker inputs. If the amps do not have linked input jacks, then use TRS type WYE connectors at the inputs. Then use speaker rated cables from the amps to the passive speakers.
Aug 12, 2011 | Mackie ProFX8 Professional Compact Mixer
2442FX. When the mixer is switched on the numerical displays on the twin digital FX units flash and the FX units don't work.
The flashing means the FX hasn't been activated yet. Dial up the number you want THEN push DOWN on the knob to activate and the flashing stops and the FX takes effect.
Mar 29, 2011 | Behringer XENYX 2442FX Mixer
I cant figure out how to connect my xenyx 1832 fx to my desk top computer
alcuni canali non funzionano metto il microfono e non va lo metto in un altro canale funziona come mai? salve e grazie gioago 1
Mar 28, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
My macbook pro will not identify the usb mixer. it said the mixer would work with a mac or pc, so what can i do to make them compatible?
hello, I have a behringer 1832. the issue I have is that the right channel is out all together. both subs work. it is only the right main. do these things have some sort of mono switch that I don't know about?
Nov 21, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
Sep 23, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I need the part number for the volume slider on a 1832 fx mixer p
I don't think you require a part number for your mixer, ring the company and tell them what model you have and I'm sure they will be able to assist you in regards to your volume slider.
regards Col
Aug 02, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How to hook up alesis air fx to 16channel makie mixer what jack it goes into
Go to http://www.zzounds.com/item-ALEAIRFX.Under the picture you will see About This Product. Click on DOCs and you can download the manuals for it. Read the manual carefully and it is explained very well. Use your mixer manual to get the best set up. I would recommend using it in an FX loop that lets you mix the individual channels FX into the output you have hooked up to your computer.
May 17, 2009 | Alesis Music
Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx  USB Logo
240 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
