Blank screen on set up - Computers & Internet
  • 111 Answers
Try to clean your memory connectors using a pencil eraser.
Posted on Apr 18, 2008
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
BELL HOWELL 17462 PROJECTION SET TV SCREEN WENT BLANK
Do you still have sound? Can you see light at the back of the set when the screen is blank -if so the bulb is ok and you've just lost video.
Oct 14, 2009 | Televison & Video
Screen goes completly blank what ever I am using on my PC. Have to press windows key and retrieve minimizes page to view. Any ideas please
see power settings in control panel.
It must be set on blank screen after 20 mins or something like that.
set it like this
turn off hard disk- never
blanks screen - never
set never with everything
cheers
Jun 22, 2009 | Dell Studio 1737 Laptop
Delayed video, audio comes first
It's normal for Sony TVs to have a delay in the video. The screen stays blanked until the circuitry in the set has decided that the picture tube is operating correctly. The screen can remain blanked due to a number of causes. Bad solder connections or components in the vertical output stage are common. Also, Sony sets automatically adjust some tube voltages. If the tube has aged enough or component values in the set have changed and the adjustments don't keep the values in the correct range, the screen will blank out. Intermittent components or connections in the set's video stages or source switching can cause screen blanking. Unfortunately, this is one of the tougher Sony problems to troubleshoot. It usually requires the schematic and an oscilloscope to track down.
May 03, 2009 | Televison & Video
Blank screen
Goto settings & tools, then goto display setting, then brightness.
Then goto messaging and then setting and then callback #
Dec 30, 2008 | Motorola Mobility MOTO W755 Cellular Phone
Screen going blank
try checking your power settings by right clicking on an empty space on your desktop and choose properties. then select the screen saver tab, then clik on the power button, on the power scheme settings, select 'never' on each box then click 'apply' and 'ok'
hope this helps!
Oct 22, 2008 | Computers & Internet
I have a panassonic 50" plazma tv, when using it as a pc monitor the screen goes blank how do i stop this, many thanks, patsy
Does the screen go blank after the computer has been sitting unused for a while or is it immediately blank and does not show a picture. If it goes blank after a while, look in your power settings under control panel on your computer and set the monitor cut off to NEVER, also check your screen saver settings. If it does not show a picture at all check the user manual of your TV to see the supported computer resolutions and then check under display settings on your computer to see if the resolution that you are using is compatible. Hope this helps.
Apr 02, 2008 | Televison & Video
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Computers & Internet Logo
141 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
