Question about Dell Computers & Internet
Dell motherboard gx260 is reset when we start computer
  • 621 Answers
You will no doubt find that the backup battery on the motherboard is flat. Replace it
Posted on Jul 14, 2010
The difference between gx260 and gx270 computers are
Dell Optiplex GX270 is newer than GX260. Hence, GX270 is better in terms of chipset, higher processor and memory support, video performance etc.
Detailed specifications GX260 & GX270
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Computers & Internet
My motherboard is dell GX260 when I trun on my computer it make 6 beeps what problem has my motherboar?
Starting the Dell Diagnostics From Your Hard Drive
  1. Shut down and restart the computer.
  2. When the DELL™ logo appears, press <F12> immediately.
note.gif NOTE: If you see a message stating that no diagnostics utility partition has been found, run the Dell Diagnostics from your Drivers and Utilities CD.
If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer through the Start menu and try again.
  1. When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
  2. When the Dell Diagnostics Main Menu appears, select the test you want to run.
Oct 28, 2010 | Dell OptiPlex GX260 PC Desktop
I have a Dell Desktop GX620 with 1 gb Ram, 250 GB HDD and Pentium D Processor. Whenever I use the System, it will start and then after a proper shut down. I will start the system again, the three beep...
Here is a link to a manual for this computer.
http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1166448
Look where it states Diagnostics lights and see if the light patterns in the back panel lights match any on the list. It might help you on pin pointing your issue. If it is a memory issue and you have already replaced it then it is the motherboard.
found this link on ebay.com
http://shop.ebay.com/?_nkw=Dell+Optiplex+Gx260+motherboard&_sacat=See-All-Categories&_fromfsb=&_trksid=m270.l1313&_odkw=Dell+Optiplex+Gx260&_osacat=92924
Oct 26, 2010 | Dell OptiPlex GX260 Intel Desktop PC -...
Will a dell gx280 motherboard fit into a gx260 (dell) case?
If it is a slim gx260 case, it might not. If it is the wide case, it will, but the two motherboards have different power supplies. You will need to use a gx280 power supply to power it on. However, you can use a gx270 motherboard in a gx260 case without changing the power supply.
Hope this helps!
Oct 26, 2009 | Dell OptiPlex GX260 PC Desktop
Dell optiplex gx260 motherboard reset
the front panel header configuration of that particular motherboard.
4e233df.jpg 6-8 (red) is your power sw
2-4 (green) is your power LED
1-3 (yellow) is your HDD LED
5-7 (purple) is your reset sw
black is not connected
The motherboard should go into a custom case no problem.
Oct 21, 2009 | Dell (E210882) Motherboard
Looking to see the inside of a dell gx260
here is the inside http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htm
here is a picture of the actual mobo http://img.photobucket.com/albums/v364/computer-reclaim/Motherboards/DellGX260towermotherboardP4.jpg
Mar 27, 2009 | Dell OptiPlex GX260 PC Desktop
Orange power switch light Dell Gx260
Gx260-Gx280 have a known issue with the motherboard capaciators. Take a look at the capaciators on the motherboard and check if any look like they have bludges at the top particularly around the memory banks. If any of them look like this the motherboard most likely needs to be replaced.
Dec 29, 2008 | Dell OptiPlex GX260 PC Desktop
Dell Computer Refurbished Optiplex GX260
from what I can tell you can use NORTHWOOD CPUS or POWERLEAP modified cpus on the GX260 but not prescott. as these are incompatible
http://support.dell.com/support/edocs/systems/opgx260/en/ug/specs.htm#1110653 would suggest 400 or 533 based P4s
using Powerleap's configurator http://www.powerleap.com
it appears that it is possible to use an Intel P4 3.06GHz 533MHz 478pin 512K Northwood CPU w/Hyper-threading OEM
Oct 03, 2008 | Dell Computer Refurbished OPTIPLEX SX270...
Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Sep 24, 2008 | Dell OptiPlex GX260 PC Desktop
An old Dell Optiplex gx260 just won't turn on
Possible failures are:
  1. Powersupply failure
  2. Motherboard failure (Check the capacitors for popped ones)
  3. Front I/O Panel
Sep 01, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
43 people viewed this question
Alun Cox
