Question about Amana Heating & Cooling
Schematic diagram for Carrier Split unit model 38AE 064 610-4
  • 86 Answers
SOURCE: I am a ac tech
mail me wht is yr requirement
1 compressure.
i can send u wht ever u want
mintex007@yahoo.com
Posted on Mar 16, 2008
bobotfel
  • 236 Answers
SOURCE: not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
Posted on Jan 08, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 14 Answers
SOURCE: I have a carrier split unit model#38HDL024311.
Where is water dripping? Out the outside unit or inside? Evap. Coils (indoor coils) condense when cooling so it is necessary to have a condensate drain hooked up. If the unit is leaking out of something besides the drain like out of the coil case then you have a blockage in your condesate line either in the drain pan under the coil or somewhere in the line that leads to your drain. blow the line both ways with nitrogen or pull the line out and clean it with a hose.
Posted on Jul 29, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
I have an Intertherm split unit A/C and electric heat I need a ladder diagram for the indoor fan relay and I also need to know which part number it is my intertherm model number is e2ebo15hb any help would...
Hi, the schematic would be in the indoor unit, but I am assuming its gone since you are looking for the ladder schematic for the heat strips and fan control. You might try this number for a schematic, 1-888-441-6942, Route A/C and they may be able to help you on this diagram. The number you are showing does not look like any model number at all. For both the indoor and outdoor units on the Intertherm, would look something like this...., P3RA-024k for the model number, and the serial number would be right below it. Both should be very easy for you to locate. It is very hard to find schematics for units once they are gone, as some tech's like to take them off units to go home and try and study them!!, unreal! Makes it hard to troubleshoot when you need it. Try to find numbers like I have noted, and call this number as they will answer questions you may have concerning yours. I hope the best for you and would like for you to rate me, as I know you will be kind. Please keep me posted on this as maybe I can help you solve this fan relay problem you have?
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 18, 2010 | Intertherm Heating & Cooling
Wiring schematic
http://friedrich.com/downloads/Ductless_Service_Manual_MW18Y3F_MR18Y3F.pdf
go to this web site. The manual has a diagram that you are looking for.
Hope this helps
Apr 18, 2010 | Friedrich MR18Y3F Split System Air...
Carrier 19000btu split, cuts out
Have you replacing main PCB board?
Jul 09, 2009 | Heating & Cooling
Carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Mar 30, 2009 | Carrier 38CKC042 Air Conditioner
Carrier multi hi wall split a/c
I don't have a diagram, but maybe I can help you. You have 2 compressors, o.k. 2 stage system. A single phase contactor? do you mean a single pole, one side breaks, the other is always hot? Speaking of phases, is this a commercial unit with 3 phase? Also, Each compressor needs a separate contactor to carry the load. What is the question?
Dec 22, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
367 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
