Question about ASUS Z83V Notebook
All of a sudden my 2nd monitor won't show image - just has screensaver
  • 487 Answers
Hi, not sure but I take it you are using two screens. It sounds like an imput problem, either cable or a graphics. Try changing your cables over and see if the problem persists?
Posted on Jul 07, 2010
Tip
My Pictures Slideshow screensaver
Make use of the Windows XP's My Pictures Slideshow screensaver for this purpose. Follow the steps:
Using Paint brush (mspaint.exe), create 10 or more images with a Black background in each. Open each image file and embed your company logo in it, in (place it in random areas, one in each image).
Create a folder for the image files you've created, and place the images in that folder. Assign this folder read-only permissions for all the users.
Now, configure the screensaver under your user profile. In the My Pictures Screensaver properties, do the following:
Set the folder where you've stored the image files
Set the interval using How often should the pictures change slider.
Uncheck all the checkboxes at the bottom of the dialog
Click OK and save the changes
Set the Screensaver Timeout to a preferred value in minutes
Test the Screensaver in your profile to see everything is fine
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Monitor blinking on and off. I had this problem once before with this same monitor. When you went from the screensaver to the desktop it would flicker back and forth between the image and the black. After...
Please read below if you decide to DIY:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 19, 2010 | Samsung 206BW Monitor
Screen suddenly does not display image just
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 19, 2009 | ViewSonic VA912BWB 19" LCD monitor
When screen comes out of screensaver/sleep mode,
It's a bad LCD screen or bad video card. If its a laptop, try to hook an external monitor to the video port in the back and see if it has the same problem. If it is the same problem, then you know its the video card and not the monitor screen. If you have a desktop PC that has this problem, its most likely the video card. First try removing the monitor and trying it on another computer to see if the monitor is bad. If not, then remove and replace your video card and restart. If same problem, replace video card with a new one.
Sep 16, 2009 | Computers & Internet
Monitor picture turns on its side when it goes to screensaver
Sounds like your screensaver is using a picture of your desktop in it's code intentionally.
Right click on a blank area of your desktop --> select properties
--> click screensaver --> change it to "none" or another screensaver
Jan 17, 2009 | CTX S762A 17" LCD Monitor
Dell monitor screen jumps and screensaver won't ever turn on.
first turn hibernate off. this is probably causing problem with your screensaver. when you say your screen jumps that leads me to believe that your monitor is probably on its way out. If you can try to hook up a diffferent monitor and see if you have the same results
Dec 30, 2008 | E-Machines eMachines Desktop PC
Screen saver
A single image cannot be set as a screensaver unless you are running some kind of slideshow screensaver software. Single images can only be set as background or wallpaper.
Sep 07, 2008 | Acer Aspire 5100 Notebook
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Respectable Sir,
DOES TOSHIBA LOGO OR SCREENSAVER SHOW AS COMPUTER IS TURNED ON.
BETTER YET DO YOU HAVE ACESS TO ANOTHER MONiTOR FROM A DESK TOP IF SO CONNECT MOINTOR TO THE LAPTOPS EXTERNAL MONITOR CONNECTOR (BLUE IN COLOR) MOUNTED ON SIDE OF LAPTOP OR BACK IF VIDEO IS VISIBLE ON THIS new MONITOR YOU HAVE AN INTERNAL VIDEO DISPLAY connector PROBLEM or bad display
Nov 13, 2007 | Toshiba Qosmio G25-AV513 Notebook
ASUS Z83V Notebook Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
