Question about Plumbing
How do i read a electrical pump panel circuit diagram in general no particular make. also would like to know about the panel design for star delta connections
Sir ihave don on panel wring but i want more on electring drawing.so whay is the course i want to do
Posted on Dec 01, 2010
No power to fuel pump on my 2001 Kia sportago
Did you check the fuel pump relay ? The relay is turned on by the ECM - engine computer . Do you know how to test automotive electrical circuit's ? How to read a wiring diagram . Have a DVOM - digital volt ohm meter ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on engine ,then under subsystem click on fuel pump . Click the searc button , then the blue link. Watch video's on youtube on fuel pump electrical testing . Fuel Pump Electrical Circuits Description and Operation
May 20, 2018 | Kia Cars & Trucks
Where is the safety fuel shut off switch 2005 pt cruiser with 2.4 liter turbo
Doesn't have one . Looking at a wiring diagram to view fuel pump electrical circuit would show that . Do you know what automotive electrical wiring diagrams are ? Do you know how to use one along with a DMM - digital multi-meter to test electrical circuit's ? The fuel pump is controlled by the PCM - engine computer by energizing the fuel pump relay .
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model ! Under system click on engine ,then under subsystem click on fuel controls . Click the search button then the blue link. Scroll down to the fifth diagram .Fuel pump electrical circuit .
Jan 15, 2018 | Cars & Trucks
I have a 2007 HHR, my temp gauge stops working and the same time the a/c stops blowing cold air...I called myself checking fuses and a relay, can you help?
You mean the blower motor stops blowing air , the A/C compressor is still engaged ? The temp gauge shouldn't have anything to do with the blower motor .But stranger things have happened on these systems when they are controlled by a electronic module (BCM )
Circuit/System Description
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the engine control module (ECM). The ECM sends the temperature data via high speed GMLAN serial data to the body control module (BCM). The BCM then sends the information via low speed GMLAN to the IPC in order to display the engine temperature.
The BCM applies voltage to the blower motor through the HVAC relay. The resistors and the blower motor are in a series circuit. The following list represents the number of resistors in series with the blower motor per particular speed request:
• Low speed--4 resistors
• Medium 1 speed--3 resistors
• Medium 2 speed--2 resistors
When the operator requests High speed, the HVAC control assembly applies ground directly to the blower motor through the high blower motor control circuit.
Do you know anything about automotive serial data communications ? GMLAN Is general motors version of C.A.N controller area network .
How to Diagnose Controller Area Network CAN
Do you know anything about diagnosing automotive electronics ? Using a digital volt ohm meter ? Using wiring diagrams to pin point locations in a electrical circuit for testing ? Do you know what a factory componet location diagram is ? It takes more then looking at fuse's an relays , to see if current is flowing in a electrical circuit .
Electric Testing Techniques You Need to Know
ECM Inputs and Outputs Diagnosis
http://www.bbbind.com/free_tsb.html Free wiring diagrams ! Enter vehicle info. Year , make , model and engine size ! Under system click on HVAC , under subsystem HVAC Controls . Then click the search button , then click the first blue link . This is the blower motor control diagram . Do you know how to read a wiring diagram ?
Apr 30, 2017 | Cars & Trucks
I have a 92 dodge stealth rt car will not start unless I spray starting fluid into the throttle body.I had new fuel pump installed due to old pump had no pressure.Car will still not start even with new...
Did you check fuel pump electrical circuit ? Look at a wiring diagram to see what all is involved in making the fuel pump work. No , the knock sensor can't cause this ! Do you know how to do automotive electrical circuit testing using a DVOM - digital volt ohm meter ? How to read an use a wiring diagram to pin point areas for testing in a electrical circuit ! What do you think makes that fuel pump work ? AIR !!!! Looking at a wiring diagram I see a fuel pump relay that gets B+ voltage from the engine control relay. The engine computer energizes both, relays .There is a fuel pump resistor inline before the fuel pump.
Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size. Under system click on engine then under subsystem click fuel controls ! Click the search button then the second blue link . The second diagram down shows the fuel pump electrical circuit .
Watch this videos from youtube .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
Jul 06, 2017 | Dodge Stealth Cars & Trucks
Motor starter
verify all three legs of the power are on. You could have a single blown fuse that would cause the motor to single phase and not run.
Apr 27, 2013 | Electrical Supplies
What is the use of wye delta?
I don't know why your question is bound to this special breaker.
If your question is common, the wye/delta is a way to reduce the starting current of a large three phase asinchronous motor.
When a three phase motor is first connected in wye (star), the starting (peak) current is about 3 times less than this in delta. When already in motion the electromotive force will make the peak current when turned in delta much less, than that with a stopped motor.
Aug 08, 2010 | RTO Telemecanique Gv2 Ls22 Magnetic...
Star delta starter circuit digrame and wring
Try www.searspartselect.com and input your model number. Frigidaire usually has the wiring diagrams as part of the illustrated lookup. If not sorry its usually last picture in breakdown.
Jan 30, 2010 | Frigidaire Electric Dryer
Won't drain need diagram for washer
If you need to know the diagram is found in control panel .Check for voltage to pump also make sure a sock is not stuck in pump .
May 18, 2009 | General Electric WCSR2090D Top Load Washer
Need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
My 95 Kia Sportage has a short in the wire running to the fuel pump what should I do?
Do you know how to find a short circuit in electrical circuits ? No !
Finding The Source Of Electrical Shorts In Your Car
Is the circuit blowing the fuel pump fuse ? No not shorted . Where does the whining noise come from ? Do you know how to do automotive electrical testing ?
Do you know what a wiring diagram is , how to read an use one to pin point loactions in a electrical circuit for testing purposes .
Do you know the fuel pump is controlled by the ECU - engine computer . Do you know how to test a fuel pump electrical circuit ?
Testing Electric Fuel Pump Problems with Voltage Drop Test
Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size . Under system click on engine . under subsystem click fuel controls .then click the search button .Then on the top blue link .Second diagram down is fuel pump electrical circuit .
Do you know how to test a relay ? Relays all work the same ,
VEHICLE RELAYS Operation Diagnosis
May 10, 2017 | 1995 Kia Sportage
Plumbing Logo
164 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
