Question about Coolmax HD-211-eSATA Hard Drive
No readings from the drive - Coolmax HD-211-eSATA Hard Drive
  • 518 Answers
Check data cable { ribbon type} and power cable are secure,when switching on the bios read out shows what is on the computer,seeif the computer has seen it if not then cables or the drive is faulty
Posted on Jul 07, 2010
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
I can read data cd but cannot read data dvd
Are you sure that the drive you are trying to read the DVD with, is actually a DVD drive and not a CD drive? Check on the front of the drive draw, it should say DVD on it. If not you will need to purchase a DVD drive to read DVD's. Nik.
Jun 30, 2009 | Computers & Internet
Computer won't read hard drive in bios nor on start up
The first step is to ensure the hard drive is functional. Test it on another machine. Then check if the computer has the ability to read the newer drive. There may also be a bios update that may allow recognizing the newer drive.
Dec 03, 2017 | Seagate (ST3120026AS-RK) 120 GB Hard Drive
Dell2 2400 BIOS F2 reads backwords.
It sounds like you may have the IDE cables hooked up backwards on your motherboard.. The IDE cable slot on the motherboard labled IDE1 should be where your Hard drives are if you want them to read as primary. The Optical drives are usually on IDE2, designating them as secondary.
Let me know if you need more help.
Mar 12, 2009 | Dell Dimension 2400 PC Desktop
Disc won't read
what type of zip disk are you trying to read? if it is larger than 100MB, the drive will not be able to read it.
can you read other disks? can you see the drive in my computer?
what operating system are you using, and how does does this drive connect to the computer? USB? Firewire?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
The Z1D CITIZEN floppy drive on this computer cannot read disks. When you put a disk into the drive, it constantly returns a dialog message in windows asking to format the drive - and cannot read any of...
some floppy can read and some floppy cant read
it means that ur floppy drive reads the information which they originally save it from citizen floppy drives. Floppy drives like citizen if u use in any place u can use the citizen floppy drive any where
Feb 15, 2008 | Citizen 1.44MB 3.5-Inch Floppy Disk Drive...
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
CDROM drive does not read some CDs
best and most affordable solution - replace the cdrom drive.
Sep 23, 2007 | Toshiba Satellite P15-S479 Notebook
Coolmax HD-211-eSATA Hard Drive Logo
74 people viewed this question
Top Coolmax Computers & Internet Experts
Paul Bade
Chippy Skippy
Chippy Skippy
Lawrence Oravetz
Are you a Coolmax Computer and Internet Expert? Answer questions, earn points and help others
