Question about Lakewood 16" Stand Fan
How to make the fan rotate so it doesn't just stand still?
Motor replacement
Sorry. That's what happens when you buy a store brand.
May 09, 2013 | Hampton Bay 92650 Stand (Pedestal) Fan
My AWIA HS-TX426 can't play cassette tapes
John Check if the capstan is rotating This is a shaft that touch the rubber wheel in the cassette Does the motor run properly? You say it is new then it should be under warranty take it back to the supplier and they should repair or replace it. If it was standing for a very long time i.e. 20 or more years then the mechanism is bound and if you know what you do then lubricate with sewing machine oil on all levers and shafts the motor can also do with a single drop ( 1 millimeter wire dipped for 25 mm in the oil and the oil that drops off, is the size of a measured drop of oil) I did get some Revox machines that were standing for such a long time and I had to use a pump pliers to get those wheel to turn they were BOUND but after playing it for a while they became working again
Apr 24, 2013 | Audio Players & Recorders
Car overheats while standing
The radiator fan doesn't work , the problem may be or the fan itself , or the sernzor that activates the fan or poor contact at the senzor
Sep 12, 2012 | 2008 Peugeot 308 1.4
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
Top arm stopped rotating on Bosch clasixx
not worth fixing, you are better off putting that money towards a new one. unless you can find the arm and repair it yourself
Nov 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
Good Morning, I have a Hunter foor standing,
Hi medoody...
Sounds to me like you need to disassemble,clean and oil your fan.
After 5 yrs of running it probably needs it badly.
Please take time to rate me
Aug 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
WHAT WAY DO THE FANS NEED TO ROTATE, IF U STAND RIGHT IN FRONT OF THE CAR
Never think of it as standing in front of the car. Always explain the location, side, or area of the car as if sitting behind the driver's wheel. Clockwise from behind the wheel (counter clockwise if standing in front). See it alleviates that problem. Look at the angle of the fan blades. They should be pulling air in.
Mar 02, 2010 | 1996 Chevrolet Impala SS
Fan blade is not rotating but there is noise
The rotor is stuck and the fan blade will not rotate then a humming noise can be heard. It is due to a bushing problem. It may be stuck due to a hardened accumulated dirt.
  1. Remove the fan blade guard.
  2. Remove the fan blade.
  3. Remove the 4 screws holding the stator assembly.
  4. Pull out the front plate of the motor and the rotor.
  5. Clean the bushing and the rotor.
  6. Lubricate the busing and rotor assembly.
  7. Reassemble in reverse order.
Nov 27, 2009 | Lakewood 16" Stand Fan
Lakewood 16" Stand Fan Logo
77 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
