Question about Fisher and Paykel AeroSmart DE62T27D Dryer
The dryer bangs like it's hitting something on every revolution. Do you have any idea what could be causing this?
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerThe dryer bangs like it's hitting something on - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 11, 2010
The tub moves to freely and bangs on the washer sides
The tub shouldn't bang on the inside of the washer cabinet, as you already know. That is not a "normal" way for it to fail. Rather, I suspect something else. First try this: If you have your washer right next to your dryer, the washer itself is probably banging against the dryer during specific times during the wash - but most likely during the spin cycle. If you spread them apart a little bit - or stuff a towel or two between them, you may find that it stops banging. The washer may also be hitting something other the dry, too. Check all around the washer - try to keep and inch or two between it and anything else. If it still is banging - then something else is causing it.
Jun 10, 2011 | Maytag Washing Machines
I have a frigidaire stackable washer/dryer unit. The washer works well. But, recently, the dryer started making funny noises almost every revolution like something was banging inside at a certain point....
Try to move the drum manually. if unable to run your hand along the front of drum where it meets the front panel....there are two pieces of felt. something has either gotten stuck there or something has gotten stuck in the blower housing.
Jun 09, 2009 | Dryers
Banging noise as dryer spins, wore hole in side of dryer
I need to know your make and model number in order to give proper advice. Joe
Nov 07, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Clunking maytag dryer
the machine is opened and inspected from the front
opening from the front there is no heavy lifting or moving of the dryer needed,
the usual causes of a ' cyclic clunk '
a worn spot on a drum felt. when that area reaches the bottom, the weight of the
drum causes a clunk.
a damaged belt that clunks when the tear hits the drum
a collapsing drum roller(replace in pairs)
each is easy to fix, cheap,
Sep 03, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Frigidaire Front Load Dryer
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
Sep 07, 2007 | Dryers
Dryer makes banging noise
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
Oct 02, 2006 | Maytag MDG9206 Dryer
Fisher and Paykel AeroSmart DE62T27D Dryer Logo
258 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
