Question about JVC CH-X1100RF 12-Disc CD Changer
I need to know how to remove the cd changer, when the changer button to reject is broken. also it is mounted in a motor boat 2002 Maxum 3000 csr? Or how do you remove the entire sys.Thanks john K
  • JVC Master
  • 17,130 Answers
Dear John, I assume that the eject button on your changer is defective for which you wan to remove the unit. Usually the changer is mounted by two sets of L-clamps. it will be fitted at the bottom or side mounted. removing the screws on the sides can get your unit dismounted. there is a power cord and a bunch connector which you can remove and disconnect. If you have the broken key of the eject, use a good glue to fix, if not you will need to fix a fashioned button that can be glued into the panel that will touch the small button switch within. Normally the button would be found inside if it broke while on action. Hope this helps! Good day
Posted on Jul 08, 2010
  • Donald DCruz
    Donald DCruz Jul 08, 2010
I have a broken motor strut on my wellcraft boat
engine mount thats bolted to side of engine ?? if so then lift engine enough to remove and repair or replace it !
Jan 24, 2014 | Boating
2001 Yukon Denali CD changer ERROR light
Try pulling the fuse for the cd changer with the ignition on, and then plug it back in. If you are lucky you might reset the unit, otherwise the changer will likely need removed sent in for repair or replacement.
Jan 18, 2012 | Cars & Trucks
Have a 12 disc player, played great, added cd's and get code 1E3
I presume you have a fault in your mechanism that is giving the wrong signals to the processor to hang up. Reset the changer if there is a preset present. Further you will need to remove the CD's from the changer and check if any of them are warped or damaged.Do repeat to load one cd and test, if this works then you are encoundering the fault when the changer loads, changing the trays. Look into the tray section for any change in the alignment.Clean off any dirt on the mechanism,look out for any broken flexible cords that moves for the motor drive. Also look out for any motor jamming of the load motor and the drive motor. You will need to look carefully for such faults to remove this error.
I hope this helps. Good day
Jul 07, 2010 | JVC CH-X450 12-Disc CD Changer
Changer will pick up CD and spin for about three seconds stop, set still for about four seconds. CD will not spin again reject CD back into the rack. the above will happen again but during the four second...
This sounds like an issue with either your CD player, CD control board, or Selection and Credit Computer. I can help you troubleshoot further over the phone (and repair/replace whatever is necessary). My name is Rod and I can be reached at tech@wurlitzer-ohio.com. Please email me and I'll email you my telephone number.
Jun 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
2000 jeep grand cherokee limited 10 disk cd changer says ''err''
The in-trunk units have a tendancy to go bad. you can take the cover plastic interior cover off to access the CD changer, un bolt the changer, and visualy inspect the two rollers for debris, or missing /broken gears that move the rollers to take the CD from the CD cartrage to the player. if that looks fine, chances are that the laser went bad (common in rear mount units) and you can order a new one from Jeep, or you can remove it and update the in-dash head to an aftermarket of your choice (& yes you steering wheel controls will still work). you could also fit a more modern MP3 unit where the Changer was.
Feb 20, 2010 | 2000 Jeep Grand Cherokee
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Oct 23, 2009 | 2002 Honda Accord
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Installing a cd changer into a 2002 Jaguar S-Type
SOUNDS LIKE YOU HAVE A VERY EARLY MODEL CD CHANGER ALPINE UNIT THE S TYPE
USED A AUDIOVOX CD CHANGER HOPE THIS IS USEFUL
Jul 03, 2008 | 2002 Jaguar S-Type
STUCK CD
you will have to remove and open the changer, and remove cd that way, hope this helps
Jun 22, 2008 | 2002 Ford Escape
JVC CH-X1100RF 12-Disc CD Changer Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
