Question about Startrac Fitness Products Star Trac 3900 Treadmill Remanufactured
Star trec 4500 no rpm mother board problem as all else is working,
    President:
  • Startrac Fit... Master
  • 832 Answers
Check the motor leads going into the L/C circuit below the MCB If you see a burnt board where the leads plug in then this is the problem if you can remove the board take it down to you local TV/ computer store and have the tech clean and hard wire and soldier the spades back. This is a common failure on this Star Trac Model
Posted on Jul 20, 2010
  • 4 Answers
I have a Startrac 4500 that gives a no rpm error occasionally. It normally works fine, but sometimes gives this error. The unit is in a garage and the problem occurs during a cold and damp spell. I have stripped it down previously but to no avail, but I have found a simple way to fix my machine. lift the motor cover and blow hot air across the boards and motor for a few minutes from a hair-dryer. Don't get things hot, just enough to take away the dampness. This has fixed the machine for 2 winters now.
Posted on Mar 08, 2012
Lower control board red light doe not blink on star trace 4500
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20TR4500.pdf
May 11, 2014 | Startrac Fitness Products Star Trac 4500...
Star trac 4500 display board does not come on
You should first check the power from the wall outlet and then follow the power going into the machine -- once you find the place where the power stops, you will find the problem.
Jul 31, 2013 | Startrac Fitness Products Star Trac 4500...
Star Trac 4500 el r n g
All the error codes can be found in the service manual in section 3.
Jan 21, 2013 | Startrac Fitness Products Star Trac 4500...
My horizon treadmill immediately stops after 2 seconds
StarTrac 4500 Treadmill NO RPM Error Probable Cause A) Damaged or misaligned RPM sensor
B) Display Cable
C) MCB
D) Filter Network
Corrective Action A) Check the connection of the RPM sensor to the lower control board. Inspect RPM sensor and disc for build up of dirt, dust, or debris. Clean if necessary. Verify RPM sensor and disc are properly aligned. Units equipped with an "optical" RPM sensor (uses plastic RPM disc) should have the disc evenly spaced between the walls of the RPM sensor. Adjust if necessary. Units equipped with a magnetic "cherry" RPM sensor (uses a metal RPM disc) should have the sensor spaced 1/8" away from the flywheel. Adjust if necessary. B) Inspect the display cable for any nicks or breaks. Replace if necessary. If there is no visible damage to the display cable, wiggle the display cable to verify intermittent connection. If by wiggling the display cable, the PWM LED on the lower control board does not flash or intermittently respond, replace the display cable.
C) Refer to the NO RPM Flowchart from the service manual for MCB testing.
D) Refer to the NO RPM Flowchart from the service manual for testing of Filter Network.
Star Trac 4500 Treadmill NO RPM Error Code
Jun 28, 2012 | Startrac Fitness Products Exercise &...
No RPM What is wrong
Jan 04, 2011 | Startrac Fitness Products Star Trac 4500...
Where can I buy parts for a Reebok Body Trec elliptical? I need the XL105 Main Board .
The XL105 is the power supply and brake controller board. These are not available anywhere that I could find, but this guy in Canada fixed mine for me. http://kitchener.kijiji.ca/c-services-computer-The-Last-Resort-Laptop-Computer-Repair-W0QQAdIdZ283518619 It works like new now.
Sep 09, 2010 | Reebok RL1500 Elliptical
What is your opinon on buying second hand treadmills star trac 4500 that come with a years warranty
I may be too late with an answer but I think getting a used star trac is a bad idea it will nickel and dime you to death even before the years up
Dec 31, 2009 | Startrac Fitness Products Star Trac 4500...
Want a mother board Cd and Audio Driver for acer
download from this link
http://www.acer.co.ae/acer/service.do?LanguageISOCtxParam=ar&miu10einu24.current.attN2B2F2EEF=3736&sp=page15e&ctx2.c2att1=24&miu10ekcond13.attN2B2F2EEF=3736&CountryISOCtxParam=MI&ctx1.att21k=1&CRC=4250700633
Jun 29, 2009 | Acer Keyboard for TravelMate 2300, 2410,...
Star Trac TR4500 Treadmill. Need help connecting the display
I recently took mine apart if you still need the exact details.
Jan 17, 2009 | Startrac Fitness Products Star Trac 4500...
Startrac Fitness Products Star Trac 3900 Treadmill Remanufactured Logo
460 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
ka4iup
ka4iup
Techmotionusa.com
Techmotionusa.com
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
