Question about Sony DSR-11 DV / Mini DV VCR
Sony drs-11 hello everyboddy can somone help wiht a manual for the drs-11 a get problems wiht my firewire connection the plug is broken I need the wiring connections to the adder bords wiht the schemecits circuits to see ware is the problem my imail is
  • rehman1122 Sep 12, 2008
    I was working that machine last 6 month working perfect with fire wire but now is not working I used camera same fire wire that working ok.
    But AVI is working ok.
  • tanveerl21 Jan 16, 2009
    where can we buy the board
the problem is a easy fix , your pin connector is broken , the solution is to open unit up , take top lid off , look towards back of unit , you'll see 3 screws that hold the dv board , unscrew , order the board from a sony industrial dealer , unplug the 2 clips , reattach the new board and you are back in business with out the labor charges ..
Posted on Dec 26, 2008
I have 2 of these units and have not seen a schematic in either manual
Posted on May 13, 2008
The pc doesnt seems to detect my cam like it needs a driver or something i plug the firewire and nothing happens
This can be caused by several things. One common problem is a faulty cable. If you have another Firewire/1394 cable, try that.
A second problem is using the wrong cable. I don't remember if the VX2000 takes still photos, but if it does, many Sony camcorders have a USB connection for transferring the still photos. However, the USB connection will NOT transfer video.
A third problem is drivers. This is usually only a problem on older Windows computers. By older, I mean Windows 98, Windows ME, and the first generation of Windows XP (the first generation is "service pack 1"). However, if you have Windows XP and have done updates, then you probably have the correct driver. If you haven't done updates, then you need to get the update for Firewire/1394.
Finally, if you haven't tried re-booting the computer, that very often is needed -- especially with older (more than five years old) -- computers. Even with modern computers, the computer will often get into a state where it won't recognize peripherals. I recommend shutting off the computer completely, disconnecting the camcorder, and then turning off the camcorder. Then, re-start the computer and after it has booted, turn on the camcorder and after it is on, connect the Firewire/1394 cable between the camcorder and the computer.
Hopefully the camcorder connector is OK. I have broken several Sony Firewire connectors, and it costs about $300 to have them repaired.
Jan 14, 2011 | Sony DCR-VX2000 Mini DV Digital Camcorder
Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Sep 10, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
I can not capture video from my camera Sony DCR-HC51E
this is due to incorrect drivers choosen for cam...just uninstall all apps related to cam alongwith drivers and reinstall them...
Jul 12, 2009 | Sony DCR-HC28E Camcorder
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Aug 26, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Jun 19, 2008 | Sony DSR-11 DV / Mini DV VCR
There is a problem with the head. Mind did that after I had it on its side working. Luckily for a sticker feel into the head so it was an easy fix.
Nov 27, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 Will Not Recognize Timecode
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly:
Sep 11, 2007 | Sony DSR-11 DV / Mini DV VCR
Video capture problems
Sounds to me that the bit rate on your PC or capturing device is not as high as that now available through the firewire ports. Try increasing the bit rate in your settings and see if that helps. Or have you always used firewire?
Aug 19, 2007 | Sony Handycam DCR-TRV19 Mini DV Digital...
DSR-11 not recognized by FCP
Hello tommy_bee, Try the advice offered on this link. It has helped me
Aug 15, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 DV / Mini DV VCR Logo
228 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
