Question about Sharp Televison & Video
Sharp aquos LC-37HU4U monitor will not turn on, red light flashing. AVC system will not turn on, stays in standby mode with red light solid. Have unplugged power cords and restarted both units with same result, AVC light solid red, monitor light flashing red.
  • ronrudolph Jul 07, 2010
    Sharp aquos LC-37HU4U monitor willsharp aquos LC-37HU4U monitor will not turn on, red light flashing. AVC system will not turn on, stays in standby mode with red light solid. Have unplugged power cords and restarted both units with same result, AVC light solid red, monitor light flashing red.
    Jul 07, 2010 - I followed first time start-up procedure after disconnecting power cords and waiting for a couple of minutes before econnecting power. I first turned on AVC system and light goes to solid red on the AVC. When I then turn on power to the monitor the red light on the monitor flashes while the light on the AVC stays solid red. At this point they should both go to solid green I think.
  • ronrudolph Jul 08, 2010
    Sharp aquos LC-37HU4U monitor willsharp aquos LC-37HU4U monitor will not turn on, red light flashing. AVC system will not turn on, stays in standby mode with red light solid. Have unplugged power cords and restarted both units with same result, AVC light solid red, monitor light flashing red. Moresharp aquos LC-37HU4U monitor will not turn on, red light flashing. AVC system will not turn on, stays in standby mode with red light solid. Have unplugged power cords and restarted both units with same result, AVC light solid red, monitor light flashing red.
    Comments:
    Jul 07, 2010 - Sharp aquos LC-37HU4U monitor willsharp aquos LC-37HU4U monitor will not turn on, red light flashing. AVC system will not turn on, stays in standby mode with red light solid. Have unplugged power cords and restarted both units with same result, AVC light solid red, monitor light flashing red.
    See less
    View Other SolutionsPlease accept or reject most recent solution << Previous Viewing 2 of 2
    Solution #2 posted on Jul 07, 2010
    toy_ladi
    Rank: Guru Expert
    Rating: 86.70% , 154 votes
    The reason the light keeps blinking is because the monitor is not having anything to do, and that is as a result of it not receiving signal from any other system unit.
    First thing you should check is the connection of your monitor to the power source. You can also test your monitor by connecting it to a system unit and ensuring the cables are properly connected to see if it will come on.
    If it does the same thing, then you change the signal cable and the power cord and try to turn it on. The signal cable is the cable that connects the monitor to a system unit.
    TAKE CARE
    Jul 07, 2010 - I have already tried those steps. The monitor was working fine earlier in the evening. I turned it off and an hour later turned it on and that is when I first got the red light flashing. Is there anything else I can do to test the AVC system?
  • 10,594 Answers
Let me know how many times red light is flashing on monitor?
Is it flashing once in one cycle, twice or five time in cycle?
That flashing red light is an error code that will narrow down problem section in your lcd tv.
Do you have service manual copy and some electronics knowledge, voltmeter etc if I need to check some voltage on specific circuit boards?
Thanks.
Posted on Jul 08, 2010
  • 7 more comments
    ACV unit light stays solid red
    Monitor light continuously flashes.
    I do not have tools or knowledge to test circuit boards.
    I will see if I can count number of flashes in each cycle tonight and get that information back to you tomorrow. thanks
  • Shahid Electronics
    Shahid Electronics Jul 08, 2010
    OK, there sould be long pause in red light blinks so count pause to pause and let me know to diagnose problem.
    I have service manual copy for this tv and can provide you helpful info to solve the issue.
    Thanks.
    thanks again, I will get back to you tomorrow.
    OK, no problem.
    Please do not respond this post except with red blinks info because I have to respond on your post due to site system or we will be disconnected to continue this question thread.
    Thanks for understanding.
  • ronrudolph Jul 09, 2010
    there is no pause, red light on monitor blinks continually at a regular interval, maybe once per second. I tried a restart again, disconnected power cords to both AVC unit and monitor, restarted AVC (light stays solid red), tried to power up monitor (red light solid briefly and then blinking begins). I also tried holding down power button on monitor and then plugging in power cord to monitor, still got blinking red light on monitor while light on AVC unit stays solid red.
    Shahid Electronics Jul 09, 2010
    Yes, its one time blink that you see continue blinking. It is back light inverter board problem.
    Check F7501-F7504, F7551- F7553, F7611-F7614 and F7641-F7643 burned out on inverter boards?
    Below is exploded view inside of tv that shows back light inverter boards location.
    So I need to take monitor to be repaired. Please confirm that this is only a monitor problem and not an AVC unit issue. Thanks for your help.
    Red light is blinking on monitor/ tv front that means it got problem and red blinking light is showing error in unit.
    AVC standby light is solid red that means its on standby and will turn On once get connected with monitor. Now monitor has problem so it turns AVC to standby. AVC itself seems OK and monitor has problem with back light inverter boards, this monitor has 4 inverter boards located on either sides. Check inverter boards and replace defective one to fix the issue. Local tv repair shop will help you out if you have no experience of electronics stuff repair.
    Thanks.
  • 484 Answers
TAKE CARE
Posted on Jul 07, 2010
  • 10,515 Answers
Could you please tell me the sequence of blinking ? or is it constant?
Thanks!!
    did you receive my reply to your initial question?
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Sharp aquos LC-37HV4U won't turn on just have a red light. I have unplugged the display and the AVC system. Turned back on then get a blinking red light. Turn on at the display and to goes to solid red...
when this occurs this is got only meaning: the Ignintion panel is faulty its the board/chip that gives the signal to the TV to start
to replace that part u must a serious soldering skill and and take to much risk cuz u might make more damage on that TV
plz do rate this post as good as u can
Oct 10, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp Aquos 30" monitor only
The monitor will not work without the AVC box.
Do you still have the monitor? Is it in good condition? Would you be willing to sell it? If so, please email me at info@btwconcepts.com
Apr 17, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have a sharp lc 30hv6u that needs the avc system
There is no way around AVC, You will need it. unfortunately, it's expensive and hard to find.
Oct 22, 2009 | Sharp Aquos LC-30HV6U 30 in. HDTV-Ready...
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
Display powers of with power up of AVC
This is the problem with my LC-37HV4U. I plug in the AVC and the tv/monitor and I get both red power lights (not blinking) but no green lights, sound, or picture. I mean the tv screen stays black! It seems like their is no communication between the AVC and the monitor. I thought at least the screen would light up when the power light came on and being it has it's own power source. This tv is driving me nuts!! Can anyone please help?? Thank you.
Jul 29, 2007 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
350 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
