Need help with SSI Cineplex 1500 Home Theater hook up..have all speakerwires hooked up,have 2 wire rca cable hooked up to input on system,going to output on satellite reciever, whaen I hit test tone I hear test tone, also hear sound coming through speakers,But when I cut off test tone I have no sound coming out of speakers.only sort of a hissing sound..What can I do?
  • 677 Answers
Hi, Hiss soundare from RCA cables.You need to reconnect again,but using a different cable for connection.
And also sometimes home theater acts that way during test mode, Check the manual and you will see how to set the home theater to see the mode that will allow all speakers to work. It's a normal thing when connecting a newly bought home theater.It the settings.Use the manual.
Take care.
Posted on Jul 07, 2010
  • moonrunner63 Jul 07, 2010
    Thanks for the help, but only problem is I have no manuel for this..all I have is hook up guide..
  • ikechukwu joshua
    ikechukwu joshua Jul 07, 2010
    Hi, was there any need forthe 2 top rating?could have just toldmeyou needed manual.
    (ssihtp.com/1500/1500.pdf).
Which wiring kit will I need to hook up my home theater?
Just a set of RCA cables. Plug them into the audio out on the cable box or TV.
Nov 26, 2014 | Genesis G-506 Theater System
Need to hook up LG tv to phillips cd/4 head hi fi and RCA surround sound
Hello!
Ok: I will guide yourself through "hook up" process.
1. connect your TV set to your VCR, using 3 wires RCA cable(Yellow, red, white) to "Video1" input, yellow only! The other 2(sound channels) connect to "home theater/DVD unit. Use "aux" input.
2. Connect your DVD video output. yellow or 3 colored( green, blue, red) component cables to your TV's Video 2 or "component 1" input.
Now you'll be able to use your TV as a video monitor for your VCR and DVD.
The sound will be handled by DVD/Home theater. In case your TV is a very modern, all you can get out is: direct digital sound stream. Your home theater must be equipped with coaxial(orange) input(looks like RCA plug) or optical input. Or both. You must use proper cables to connect TV to Home theater.
sorry, but it requires some patience and thorough reading of user manuals.
Otherwise, it's "level 1" difficulty. nothing you may damage, due to installation.
Good luck,
Feel free to ask for more help, if needed.
thanks,
Alex.
Dec 14, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a RCA Home Theater System RT2380BK I have the speakers wired but i want to hook it up to my dish network when I'm watching movies.Can u help me?
The dish network reciever should have audio and video out on the back, If its a HD device it should also have COAX out (hd audio) get the cables for audio and feed the into a input on the back of your home theater system, there should be several inputs, usually labled like video 1 video 2, tape deck etc etc. the audio in are red and white or red and black usually, the coax connector is orange, and you only need one cable to hook that up. If you have HD audio on the dish network that will sound best in your home theatere system
Mar 10, 2011 | RCA RT2380 Home Theatre System System
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Mar 06, 2011 | Yamaha Audio Players & Recorders
Have ssi ceneplex 1500...need help in connecting to tv..connected all wires..no sound..can you help?
Hi
You probably have your rca in the wrong output u have to put the rca yellow red and white coming out of the tv on an output not an input and put the other end in the entertainment in an input and where u plug it in it should say aux or aux 2 or video1.
Please check the bellow link for further help…
http://www.ssihtp.com/Cineplex%20220/C220.pdf
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 07, 2010 | Ssi Cineplex 220 System
What is the proper way to connect to home theater system?
Does the Sub have a Low- Level input? This is a RCA type female connector, what you need to do is run a Male RCA cable from your home theatre where it says Sub-OUT and go into the Sub woofer Line in. Unless you only have speaker wire inputs on the back of the Sub then take the Left and Right front into the Sub speaker inputs and then out of the Sub speaker OUTS back to your speakers.
Feb 28, 2009 | Omage BB08 Subwoofer
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
Need a Manual or help with System
YOU NEED TO HOOK YOUR RCA CABLES FROM YOUR DVD,TV,AND DIGITAL CABLE TO THE INPUT SIDE OF THE SURROUND. HOOK THE RCA CABLES FROM THE TV TO THE AUX SIDE AND THE DVD TO THE VCR INPUT, AND THE DIGITAL TO TH LD SIDE OF THE INPUT YOU CAN SWITCH BETWEEN THE 3 ON THE FRONT OF THE SURROUND.BY MOVING THE KNOB. YOU WILL GET NOISE FROM THEM THEN TO THE SPEAKERS.
May 24, 2008 | Emerson HT200 System
Remote control
You can get a new remote @SSI.com
Oct 23, 2007 | Ssi Cineplex 220 System
140 people viewed this question
 Grubhead
Grubhead
