Ricoh 3050 with sapsprint don't work
Ricoh 3050 don't work with sapsprint:
We have installed/uninstalled sxprint 7.10 and other versions in server
printer Windows 2003. The printer locks when printing from sap or
office toolst, we must reboot printer to unlock.
We have installed a new driver for a ricoh printer, the result is the
same.
We have readed note 1135039,the printer is not on the list.
We think that ricoh printer is not supported by SAP,the problem is
SAPSprint service is installed on the print server and the printer
ricoh can't print office tools, nothing.
4 Suggested Answers
SOURCE: Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Posted on Jan 28, 2009
Bubbabear64
  • 2794 Answers
SOURCE: Zebra Z4M plus, I am not able to print labels
Turn the printer off. Turn it back on again. Restart the computer. Restart SAP. See if that makes a difference.
Posted on Feb 25, 2009
Roop1980
  • 228 Answers
SOURCE: Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Posted on Apr 12, 2009
How to change the root password
You will definitely void any warranty you have doing that. It depends on what version of Linux it is running, do you know? Can you not just call Ricoh and ask them?
May 16, 2013 | Ricoh ECABINET 1000 (410615) Server
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
How do I uninstall adobe flash on my Mac. I am downloading it but its not working on my browser and keeps telling me I need to install it again. I guess I have an older version but of course the install...
Hi peteheisinge,
I don't own a mac but the procedure is the same as the pc. Usually the best way to fix adobe flash is to uninstall it. If you don't uninstall first then I think if the installer finds a flash related file it does not right over it. This becomes a problem on updates or if the file is corrupted.
The instructions for Uninstalling flash player on a Mac is in the link below, which goes to the Adobe Website.
On that page there is a link that says 'Uninstall previous versions of Flash Player' that will take you to the uninstaller.
The link is:
http://kb2.adobe.com/cps/908/cpsid_90893.html
I hope this helps.
Kind Regards
mparkyn
Jul 27, 2011 | Adobe Computers & Internet
Hi I have reformat my Acer aspire 3050 and he delete my drivers what should I do to get them back?
HI friend
click here to download your drivers
Realtek - Audio audio.png Acer Aspire 3050 Realtek Audio Driver for Windows Vista Enterprise 32bit
Filename: Audio_Realtek_6.01.5334_Vistax86.zip
File size: 33.3 MB
Version: 6.01.5334
broadcom.jpg Broadcom - Bluetooth bluetooth.png Acer Aspire 3050 Broadcom Bluetooth Driver for Windows Vista Enterprise 32bit
Filename: Bluetooth_Broadcom_6.0.1.3500_Vistax86.zip
File size: 19.5 MB
Version: 6.0.1.3500
bison.jpg Bison - Camera camera.png Acer Aspire 3050 Bison Camera Driver for Windows Vista Enterprise 32bit
Filename: Camrea_Bison_1.0.0.14_Vistax86.zip
File size: 9.3 MB
Version: 1.0.0.14
suyin.jpg Suyin - Camera camera.png Acer Aspire 3050 Suyin Camera Driver for Windows Vista Enterprise 32bit
Filename: Camera_Suyin_1.0.0.8_Vistax86.zip
File size: 22.4 MB
Version: 1.0.0.8
ene.jpg ENE - CardReader no_image.png Acer Aspire 3050 ENE Card Reader Driver for Windows Vista Enterprise 32bit
Filename: CardReader_ENE_5.1.2600.3000_Vistax86.zip
File size: 627.3 KB
Version: 5.1.2600.3000
conexant.jpg Conexant - Modem modem.png Acer Aspire 3050 Conexant Modem Driver for Windows Vista Enterprise 32bit
Filename: Modem_Conexant_7.62.00_Vistax86.zip
File size: 2.1 MB
Version: 7.62.00
synaptics.jpg Synaptics - TouchPad touchpad.png Acer Aspire 3050 Synaptics Touchpad Driver for Windows Vista Enterprise 32bit
Filename: Touchpad_Synaptics_9.1.0_Vistax86.zip
File size: 22.9 MB
Version: 9.1.0
ati.jpg ATI - VGA vga.png Acer Aspire 3050 ATI VGA Driver for Windows Vista Enterprise 32bit
Filename: VGA_ATI_8.332.0.0_Vistax86.zip
File size: 110.4 MB
Version: 8.332.0.0
atheros.jpg Atheros - Wireless LAN wireless_lan.png Acer Aspire 3050 Atheros Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: Wireless%20LAN_Atheros_7.2.0.152_Vistax86_A.zip
File size: 2.8 MB
Version: 7.2.0.152
broadcom.jpg Broadcom - Wireless LAN wireless_lan.png Acer Aspire 3050 Broadcom Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: WLAN_Broadcom_4.102.15.61_Vistax86.zip
File size: 2.9 MB
Version: 4.102.15.61------------------------------------------------------------------------------
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Mar 30, 2010 | Acer Aspire 3050 Notebook
Error installing MS Office pro 2007 with BCM
Uninstall from control panel the following:
Microsoft SQL Server native client
Microsoft SQL Server Setup Support files
Microsoft SQL Server VSS writer
Move directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use. Delete everything under Microsoft SQL Server in c:\Program Files
Reinstall
Jan 10, 2010 | Microsoft Office Professional 2007 Full...
Can't print in SAP R3 to HP LJ2600n
Supported HP Printer: HP Color LaserJet 2600n printer
(Host-Based)
Recommended PCL5 Device Type: SAPWIN
- requires Server-based printing via SAPSprint or Frontend Printing via SAPgui
Supported SAP Release: See SAP Note # 8928
Dec 11, 2009 | HP Color LaserJet 2600n Printer
Cannot scan
hi,
first thing keep u r printer cd ready.Second uninstall your printer from add and remove programs and also disconect the printer from computer.Know re start your pc and install printer drivers with cd dont connect the printer untill it askes to connect. once setup asks u to connect connect the printer cable to your computer.Once the setup is finished then trie scanning from printer to pc. It will work.
Achanak3
Oct 02, 2008 | HP LaserJet 3050 All-In-One Printer
117 people viewed this question
k24674
jasbo
jasbo
