Well i have Jensen home theatre speakersDX-202 DX-70 and Jensen SPX-19 subwoofers. Its the SPX-19 that i seem to have trouble in getting them to workespecially with my very little knowledge of wiring without some kind of instruction manual showing me which goes to what or where.? They are connected to a Pioneer VSX-D409 audio/video multi channel reciever with the SPX-19 being the only one's to elude me and not seem to operate even with the Blue Power operating lights showing it has power..?? Any kind of help would be hugely appreciated.!! Kind regards Troy.
  • 39 Answers
Google for manuals. Most manuals can be found for free
Posted on Apr 30, 2017
petraman7
  • 1175 Answers
SOURCE: VSX-D409 - Standby Light - Does not Power On
Hi...
Make sure all the speakers are connected properly at BOTH ends.
If still **** then seek a service tech
Posted on Feb 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: im trying to hook my
What isn't it doing - audio, video, both? What model is the TV. How are you trying to do it. Do you have the manual? The simplest hookup is to just have the a single RCA cable from "TO TV Monitor" to a Video In on the TV. Modifications may be required depending on what else you have for video sources and how they're attached.
Go here for it. Register and search for things, like vsx-d409...
http://www.retrevo.com
Posted on Apr 28, 2009
  • 35 Answers
SOURCE: Pioneer Amp VSX-D409 Volume
I have a VSX D508 Looks just like the VSX D409. Had the same prob with the volume control when I bought it. I first tried the cleaner. Better than what it was but didn't compleatly solve the problem and before long it was getting worse again.
It does have a rotary encoder instead of the traditional varible restance volume control. I finally broke down and removed it from the board and lightly sanded the contacts with fine sandpaper.
This involves removing the whole face from the main board and chassis. Not that bad, a couple screws and some ribbon jumpers and latches and it's off.
Next carefully pull the volume control straight off the shaft, remove the nut under it and lay it face down on a soft surface. Remove the screws that hold the circuit board to the face and slowley seperate the too, you'll have to release some latches also to sepperate them.
If you replace the volume control with a new one or clean the old one you have to go this far because it's soldered to the front side of the board. Yes, it has to be de-soldered from the board.
This control was not designed to be dissassembled but I was able to carefully open it and remove the shaft to totaly expose the contacts for a complete even couple of passes with the sandpaper.
I did have to use some 5-minute opoxy when I put it back together because I couldnt get the metal tabs to close as tightly as they were before it was opened.
I soldered in the volume control, put it back together and it's worked perfectly ever since. I don't know how much pioneer wants for a new one but I can tell you they wanted $69 plus shipping for a new remote for my receiver. And with this style of volume control you might be at their mercy as far as finding one from another source that fits.
Posted on Apr 03, 2010
alexander404
  • 276 Answers
SOURCE: How do I hook up my ipod to my pioneer vsx d409 ?
Use the earphone jack in the iPod to connect to your Pioneer's RCA analog stereo input (CD or AUX for example) using a cable with the 3.5mm plug for the iPod and the two plug RCA on the Pioneer side. Plug white into white and red into red on the Pioneer. See image below. You can buy this cable at Radio Shack or online at Amazon.com for very little. Be sure to select the Pioneer input where you connected the iPod.
Posted on Mar 13, 2011
Why is my Jensen SPX-17 home entertainment subwoofer only putting out about 10% functioning base power volume level and loudness?
Gary, If you have the subwoofer open, what did you keep from measuring the voltage of both power supplies? And while measuring, why not put a load on both, and see what current they can handle?
When the error moves with one component (power supply) the error must be there. Without a multimeter, (I have several, but I'm not close to the power supplies) you can't tell if the power supply is working to full performance. So start there.
Just try to find out, if a part of the rectifier is defect (one diode) It won't be possible to point out what is wrong, if you can't measure on the device yourself.
Sorry.
Nov 23, 2014 | Audio Players & Recorders
I can't get any sound out of my jensen spx-17 subwoofer
Pull the woofer out of the box and make sure it's hooked up on the inside, if so you will want to test the ohms reading off of your subwoofers terminals to make sure it's reading either 2 or 4 ohm which ever it's rated at to eliminate the woofer as the problem. After all of those have been done check your amps out put for power to the woofer and make sure your rca cables are hooked up correctly and have power.
Jul 01, 2012 | Car Audio & Video
I have a Jensen KS212 and I'm connecting it to a home theatre receiver direct to see if it works but nothing comes out of it. Does this mean the sub is not working or there's not enough power from...
Hi, welcome to FixYa..
Your subwoofer requires a seperate amplifier that has low pass filter in the pre out system, which means it will allow all low frequency signals from the input section of the amplifier/ crossover. Your receiver has combined signals of high, mid and midbass signals that will not be able to drive your subwoofer. That is the main reason why some receivers has "Subwoofer Out" to allow you to use "Active Subwoofer systems" (also known has self powered or has a built in amplifier w/ subwoofer)
For you to use your Subwoofer, it must have a seperate amplifier, connect it to Sub out of your receiver and from there you can hear the difference. Hope this helps.
Jul 13, 2011 | Jensen KS-212 Car Subwoofer
Where to purchase a subwoofer for my Jvc home theatre
You can get a complete refurbished JVC TH-A25 System on Amazon for $130. Individual components might be scarce or prohibitively expensive.
May 23, 2010 | JVC TH-A25 System
My Jensen spx 17 sub makes a loud thump on turn on.Is this normal or an easily solved problem? Will it damage the cone?
all the spx17 will do that, no it should not damage the driver.
We usually suggest to customers that it is best to leave the Sub in the Auto switch position as this will allow it to automatically switch on and off without the loud pop.
Nov 16, 2009 | Jensen Audio Players & Recorders
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
Home theatre Jensen sub woofer picks up am radio frequency during and when tv and amp are switched off. Jensen subwoofer will not switch off automatically due to the am radio frequency
somewhere in the home there is a cross of antenna wires thats putting off frequency to your system find antennas and remount for a proper wirein
or you hooked up the antenna straight to receiver
this one is tough one never heard of this before
May 07, 2008 | Audio Players & Recorders
Home theatre subwoofer
Sounds like you have a loose signal lead. Check to see if this cab be tightened if not replace the cable as this could be the cause of the problem. Over time the leads/plugs do loosen especially on subs as they vibrate so much. If it's not this then it's probably something internal to which I am reluctant to advise you on looking at yourself unless you are pretty proficient with electronics :P
Nov 08, 2007 | Jensen XS-1010 Car Subwoofer
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Aug 27, 2007 | Jensen JPS10 Subwoofer
115 people viewed this question
 Grubhead
Grubhead
