Question about Olivetti Lettera 25 Typewriter
Space bar & return have stopped working
The space bar on our Olivetti ET 2500 has stopped working. Also, the carriage will no longer return. Both problems developed simultaneously. In recent months, there were occasions when a character would not type and a beep sounded; turning the unit off then back on would resolve this. The beep now sounds when trying to space or return, but the individual letters/characters seem to be okay. The past fix of turning it off and on has had no effect.
Any help you can provide would be appreciated.
SOURCE: carriage release
try jiggling the carraige around a bit and then try using that lever thats on the right side of the carraige. you might even try both at once to see what frees it up. i had the same problem and it worked for me. That's the right tab, it may be in a jammed position so it wont open properly.
Posted on Jun 13, 2007
  • 120 Answers
SOURCE: Olivetti ET 115 Typewriter
Good luck Olivetti is out of business for 20 years. Lawrence
Posted on Feb 12, 2008
SOURCE: Olivetti Lettera 22 - carriage jammed
THERE IS A CARRIAGE LOCK ON THE MACHINE IF I REMEMBER RIGHT IT'S SO THE CARRIAGE DOSENT MOVE WHEN IT IN THE CARRING CASE. LOOK ON THE LEFT AND RIGHT END OF THE CARRIAGE JUST BELOW THE PLATEN KNOBS OR IT MAYBE A LEVER ON THE SIDE OF THE KEYBOARD
Posted on Aug 18, 2008
JUSTOLDJIM
  • 453 Answers
SOURCE: Lettera 22 - sips and adds spaces on occassion
If it skips at the same place or skips every 10 or 12 spaces all the time it is a broken tooth on the escapement wheel or rack. It could be in typing you are lingering on the key causing it to spring back a little ans space over.
Posted on Dec 08, 2008
  • 3594 Answers
SOURCE: ribbons and manual for Olivetti ET Personal 55 typewriter
The ribbons are available in the USA GENERAL RIBBON #T381 or Nukote B136 L/O G.R. #T376 Instruction book not likely. I hope you can find them a little closer to home.
DickyO
Posted on Oct 29, 2009
Testimonial: "thank you very much for the information, It was appreciated"
My olivetti typewriter et compact 66 has two arrows on display screen. Cant type or do anything.
You mat have the L & R margins set together. press but don't ho;d the MAR REL key space all the right, press the R. margin key.
DickyO
Sep 06, 2015 | Olivetti Office Equipment & Supplies
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
Olivetti Lettera 32 typwritter carriage doesn't move
If the locking lever is off, then the carriage is bound, or one of the tabs is hung, try releasing all the tabs, pushing the space bar or the tab key while gently moving the carriage.
Try all of the function like shift while gently pushing on the carriage always to the right..
also check the that the margins are not locked.
This could be a lot of different things...
Dec 18, 2009 | Olivetti Lettera 35 L Typewriter
Olivetti Lettera 32 typwritter carriage will not move?
There is a lever in front of the right knob that is used to lock the carriage.
Aug 31, 2009 | Olivetti Lettera 35 L Typewriter
Aug 17, 2008 | Olivetti Lettera 25 Typewriter
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
Olivetti Lettera 25 Typewriter Logo
49 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
