Question about Mathsoft Solving and Optimization Extension Pack III (46513) for PC
Three person mr.roy mr.paul and mr.singh together have rs. 51 mr.paul has rs.4 less then mr.roy and mr.sigh has got rs. 5 less the mr roy. they have the money as: (a)20,16,15 (b)15,20,16(c)25,11,15
How do I get Rs. 5 lakh Personal Loan in Indore?
If you want to get a Personal Loan of Rs.5 lakhs in Indore, firstly, you will have to meet the eligibility criteria of personal loan in terms of your monthly income, your other obligations, age and employment proof. Also, there are many banks and NBFCs offering Personal Loan in Indore. You will have to undertake a thorough comparison of all these financial institutions before coming to a final decision on where to apply.
May 30, 2017 | Personal Computers & Internet
What is the slope and y intercept of -2,1 and 5,-5
slope or m = (y2 -y1)/(x2-x1)
always start with the same point.
m = (1 - (-5))/(-2-5)
m = (1 + 5)/(-7)
m = 6/-7
m = -6/7
The y-intercept is the b in the equation y=mx+b.
We can use either point to calculate b. Let's use (-2,1). So every time we see x, we put in -2, and every time we see y, we put in 1.
y = -6/7x + b
1 = -6/7 (-2) + b
1 = 12/7 + b
1 = 1 5/7 + b
-5/7 = b
So, y = -6/7x - 5/7
To check, we substitute in the other point and see if the left side is equal to the right side.
LS RS
-5 -6/7(5) - 5/7
-5 -30/7 - 5/7
-5 -35/7
-5 -5
LS = RS
QED
Good luck,
Paul
Mar 23, 2017 | Homework
HAIER SERVICE CENTRE IN DELHI
Mr Inderjeet Kaur Garg Electronic Saidulahjab +(91)-(11)-41664130 6, Opp Anupam Garden, Main Rd, Lado Sarai, Delhi - 110030 Pearl Home Care, Mr Surender Yadav, Mr Rampal Yadav +(91)-9582223955, 9582223944 H 961 Palam Ext Sec 7 Dwarka, Dwarka, Delhi - 110075 Raj Electronics,Mr Mitesh Gupta +(91)-(11)-26164004, 26184581 +(91)-9871389740, 9871389741 +(91)-(11)-26101163 D-9, Mohan Singh Mkt, Sec-6, R K Puram, Delhi - 110022
Feb 12, 2011 | Haier HSB03 Compact Refrigerator
Left side of sreen is blurry/halo effect. Right side is normal. Magic focus stops when it gets to green and flashes green number 5 on bottom left of screen. (Hitachi 2003 51" projection HDTV)
SET uses two of the STK-392-150 convergence chips for this, both need to be replaced and set adjusted.
Parts cost on EBAY will be under 25 dollars. I can help if you are do it yourself person. A shop will get 250-300 for this but you can do it for much less.
Can I assist you?
SD TECH
Sep 15, 2010 | Hitachi 51F500 51" Rear Projection...
I've Aspire 4720, one of the key(Key $4) has been peeled out, where is the servicing center in Bhubaneswar so I can repair it? Please advice. Thanks, Rob
Please enquire about the two following addresses for your request...
Sprimon Technologies
Plot# 558,
Saheed Nagar,
Bhubaneswar
Orissa
ERO
751007
sprimon@gmail.com,
sprimonservice@bsnl.in
0671-2546786, 3293963
0674-2546786
Mr.Pramod Kumar Singh-09861125024
Mr.Durga Prasad Singh-094370 25467
or
Sysnet Global Technologies
Plot No.42, Flat-ST-A, Saheed Nagar,
Bhubaneshwar 751007
Orissa
kishore.mohapatra@sysnetglobal.net
0674-3204066 / 9437243610
Mr Kishore Chandra Mohapatra
May 18, 2010 | Acer Aspire 4720 Notebook
Three friends went to a hotel. The bill was Rs 75/- >Each one contributed Rs.25/-. > >The waiter took the bill to the cashier. > >The cashier was happy & decided to give them a discount...
Here you need to under stand the question properly.The waiter returned the 1 rupee to the three freinds.So the remaining 24 rupees is the expense occured for them including the bill and waiter tips of 2 re.
24*3=72(bill 70 re+waiter 2 re).Remaining one rupee has been given to each of them.
Mar 04, 2010 | HP dx2300 Monitor Personal computer Intel...
Four years ago allan was three less than twice roys age in 5years allan will be 6yeras older than roy how old are they?
Allan is 19 and Roy is 13.
Solution:
First we have 2 variables, their ages: I used Allan = x & Roy = y
Equation 1: X - 4 = 2*(Y-4) - 3
We can ignore the 5 years in the second part of the statement. Allan will always be 6 years older than Roy whether it be 5 years from now or ten years form now.
Equation 2: X = Y + 6
Substitute Y + 6 for X in equation 1:
X - 4 = 2*(Y-4) - 3 becomes Y + 6 - 4 = 2*(Y-4) - 3
That simplifies to Y + 2 = 2Y - 8 - 3
Rewrite it again: Y + 2 = 2Y - 11
Add 11 to both sides: Y + 13 = 2Y
Subtract Y from both sides: 13 = Y
Now plug 13 in for y in Equation 2
X = Y + 6
X = 13 + 6
X = 19
Oct 08, 2009 | Vivendi Math Blaster Algebra (03763) for...
Unable to import text file to access table
Hey everyone, I was able to fix my problem using the following:
filnam = Me![Text2]
Set objFile = CreateObject("Scripting.FileSystemObject")
Set objText = objFile.OpenTextFile(filnam)
Set rs = CurrentDb.OpenRecordset("FlatFileImport")
once = False
If Not IsNull(Me.Text2) Then filnam = Me.Text2
Open filnam For Binary As #1
Do While Not objText.AtEndOfStream
strTextLine = objText.Readline
Data = Split(strTextLine, ",")
If once Then
rs.AddNew
rs.Fields(1) = Data(0) 'Site ID
rs.Fields(2) = Data(1) 'Client ID
rs.Fields(3) = Data(2) 'Client Name
rs.Fields(4) = Data(3) 'DDA Account
rs.Fields(5) = Data(4) 'Process Date
rs.Fields(6) = Data(5) 'Good Checks Singles
rs.Fields(7) = Data(6) 'Good Checks Stubs
rs.Fields(8) = Data(7) 'Good Checks Partial
rs.Fields(9) = Data(8) 'Good Stubs Partial
rs.Fields(10) = Data(9) 'Good Checks Multi
rs.Fields(11) = Data(10) 'Good Stubs Multi
rs.Fields(12) = Data(11) 'Check Only Checks
rs.Fields(13) = Data(12) 'Check Only Stubs
rs.Fields(14) = Data(13) 'Check And List Stubs
rs.Fields(15) = Data(14) 'Check And List Checks
rs.Fields(16) = Data(15) 'Suspense Checks
rs.Fields(17) = Data(16) 'Suspense Stubs
rs.Fields(18) = Data(17) 'Correspondence
rs.Fields(19) = Data(18) 'Envelopes
rs.Fields(20) = Data(19) 'Express Mail
rs.Fields(21) = Data(20) 'Lookup Stubs
rs.Fields(22) = Data(21) 'Online Lookups
rs.Fields(23) = Data(22) 'Stubs Only
rs.Fields(24) = Data(23) 'StopFile Hits
rs.Fields(25) = Data(24) 'SLC
rs.Fields(26) = Data(25) 'SL2
rs.Fields(27) = Data(26) 'MICR Scanline
rs.Fields(28) = Data(27) 'KeyStrokes Correspondence
rs.Fields(29) = Data(28) 'Keystrokes SLC
rs.Fields(30) = Data(29) 'Keystrokes SL2
rs.Fields(39) = Data(38) 'Exception Queue
rs.Fields(40) = Data(39) 'COA Queue
'IMAGE ARCHIVE ITEMS
rs.Fields(41) = Data(40) 'Image Archive Reports
rs.Fields(42) = Data(41) 'Image Archive Storage
'BATCHES PROCESSED
rs.Fields(43) = Data(42) 'Batches Processed
'ARC ITEMS
rs.Fields(44) = Data(43) 'Low Speed ARC Attempts
rs.Fields(45) = Data(44) 'High Speed ARC Attempts
rs.Fields(46) = Data(45) 'Low Speed ARC Converted
rs.Fields(47) = Data(46) 'High Speed ARC Converted
'ICL ITEMS
rs.Fields(48) = Data(47) 'ICL Attempts
rs.Fields(49) = Data(48) 'ICL Converted
rs.Fields(50) = Data(49) 'ICL Non-Conforming images
'RETURN ITEMS
rs.Fields(51) = Data(50) 'Auto Returns
rs.Fields(52) = Data(51) 'Returned Items
'POSITIVE POST (CDM) ITEMS
rs.Fields(53) = Data(52) 'Positive Post Checks
rs.Fields(54) = Data(53) 'Positive Post Stubs
'REMOTE PAYMENT CAPTURE ITEMS
rs.Fields(55) = Data(54) 'Remote Payment Single Checks
rs.Fields(56) = Data(55) 'Remote Payment Single Stubs
rs.Fields(57) = Data(56) 'Remote Payment Multi Checks
rs.Fields(58) = Data(57) 'Remote Payment Multi Stubs
rs.Fields(59) = Data(58) 'Remote Payment Check Only Checks
rs.Fields(60) = Data(59) 'Remote Payment Check Only Stubs
rs.Fields(61) = Data(60) 'Remote Payment Check & List Checks
rs.Fields(62) = Data(61) 'Remote Payment Check & List Stubs
'DOLLAR DEPOSTIED & PP CORRO REJECT ITEMS
rs.Fields(71) = Data(70) 'Dollars Deposited
rs.Fields(72) = Data(71) 'PP Corro Rejects
rs.Update
End If
once = True
MyLine = ""
MyLine = MyLine & ch
MyLocation = Loc(1)
Loop
MsgBox " File has been successfully imported! "
Close #1 ' Close file.
rs.Close
'close and erase the file from memory
objText.Close
Set objText = Nothing
Set rs = Nothing
Sep 08, 2009 | Microsoft Access 2003 for PC
Cannot set dials on a Paul Jardin watch which came w/out instruct
THE OTHER 3 DIALS ARE FAKE AND DON'T DO ANYTHING,IF YOU LOOK CLOSELY THEY ARE JUST MORE OR LESS TACKED IN PLACE.
Feb 22, 2009 | Bulova Millennia Motion 96B34 Wristwatch
Mobile LCD problem
Following are the service centers which can help you, repair cost may vary depending on whether its a minor issue or the display has to be changed. Benma Infosol Pvt Ltd. Complete Address P-168/1 CIT Road, Scheme Viim, Kolkata Email Id benmainfo.cal@lgmobiles.com Contact Person Mr.Arun Surana Store Timing 9:00am to 6:00pm Contact No  (Lan/FAX/Mom no)     Weekly Off Sunday Services Available for GSM,CDMA
Friends CommuFriends Communication Complete Address 32(8) Barasat Road,N/L 15 No Railgate,PO-Nonachandanpukur,PS- Titagarh, Barrackpore, Dist- North 24PGS Email Id friends.bar@lgmobiles.com Contact Person Mr.Arup Sarkar & Tarasankar Mukherjee Store Timing 9:00am to 6:00pm Contact No  (Lan/FAX/Mom no) 25921263    9330986253 Weekly Off Sunday Services Available for GSM,CDMA
Jaksom Engineering Pvt Ltd Complete Address Block-A, Shop-1, Ambika Vihar,1/1 Harduttrai Chamaria Road, Howrah Email Id jaksom.cal@lgmobiles.com Contact Person Mr.P.Mukherjee Store Timing 9:00am to 6:00pm Contact No  (Lan/FAX/Mom no) 32950383     Weekly Off Sunday Services Available for GSM,CDMA
JP Computers Complete Address 5B Ekdalia Place, Kolkata Email Id jpc.cal@lgmobiles.com Contact Person Mr.Somim Kabir Store Timing 9:00am to 6:00pm Contact No  (Lan/FAX/Mom no) 24401923     Weekly Off Sunday Services Available for GSM,CDMA
Skylink Complete Address 8/1A, Little Russel Street, Calcutta Email Id skylink.cal@lgmobiles.com Contact Person Mr.H R Molla Store Timing 9:00am to 6:00pm Contact No  (Lan/FAX/Mom no) 32903814    9339791037 Weekly Off Sunday Services Available for GSM,CDMA
Sourav Telecom Complete Address 195 Block-J New Alipur, N/L New Alipur State Bank, Kolkata Email Id sourav.cal@lgmobiles.com Contact Person Mr.Amit Ghosh Store Timing 9:00am to 6:00pm Contact No  (Lan/FAX/Mom no) 32511256    9330998399 Weekly Off Sunday Services Available for GSM,CDMA
Sun Mobile Service Complete Address 15 B.T. Road, N/L Peikpara Bus Stop, Kolkata Email Id sun.cal@lgmobiles.com Contact Person Mr.Vivek Kumar Gupta Store Timing 9:00am to 6:00pm Contact No  (Lan/FAX/Mom no) 32505444     Weekly Off Sunday Services Available for GSM,CDMA
Feb 04, 2009 | HP Compaq dx2300 Microtower - RT950UTABA...
Computers & Internet Logo
63 people viewed this question
Top Mathsoft Computers & Internet Experts
k24674
Michael Cummings
Level 1 Expert
Bapco
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
