Question about Refrigerators
I have an old 22cf Montgomery Ward refrigerator model HMG-2270-4. An additional # listed on the schematic on back of fridge is BM-9N66A. The freezer is operating correctly, but the fridge side is not as cold as it should be. Any suggestions - I have been unemployed for a long time and can't buy another fridge right now.
  • seedygal Jul 07, 2010
    I'm looking for specific information if available about location of tube to evaporation pan to check if it is clogged, things I may be able to check myself.
    President:
  • 1,561 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Good luck.
Posted on Jul 07, 2010
    Is there a manual online somewhere or an indicator in the model # regarding who the manufacturer was for montgomery ward to help locate where fans, defrost timer, etc. are located on the unit?
  • Sulaimon Jimoh Olayemi Jul 07, 2010
    You can search for the manual of you unit from the two link belo, the links contain almost all the manuals of all device.
    manualsonline.com
    or
    manualnguide.com
    Type any of the two link above on your web browser to search for the manual of your device, the two links contain virtually all manuals of all device.
    Take care.
  • 6,993 Answers
there are a lot of reason that could make your fridge not cool properly. It might be the thermostat or the compressor. The thermostat maybe faulty or set low and the compressor may not be supplying enough gas to the fridge.
I will give you a link where you can get a detailed info of the fault and the solution top fix it. Trying to type these procedures will take a lot of time.
http://www.repairclinic.com/Refrigerator-Troubleshooting
Good luck.
Is there a manual for a Montgomery Ward compact mini freezer with this model license # 8113.07 and serial # 54020? SL?
This information is usually readily available direct from the MANUFACTURER and/or ON-LINE. If you don't have access to a computer just see your local store or give the manufacture a quick call ...
  1. Montgomery Ward Refrigerator Support ' ManualsOnline.com
    kitchen.manualsonline.com > ... > Refrigerator Support
    Montgomery ward refrigerator product support information from ManualsOnline.com. Find montgomery ward refrigerator user manuals, instructions, and free ...
Sep 20, 2014 | Refrigerators
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
Freezer is working fine-but refrig is not cooling. Refrigerator is about 15 years old, side-by-side.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 25, 2011 | Montgomery Ward Refrigerators
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Oct 04, 2010 | Montgomery Ward Refrigerators
Model HMG 21674 About how old is this model, trying to decide to repair or buy new! Thanks.
with out knowing the producton number i am showing this model to have a twelve year run
88-2000,
10 years is the expected life of most units now adays, so even if you were at the end of production
your pushing 10 years now
i would just buy new,,,, fixing one problem could only open a very exepensive can of worms
Oct 27, 2009 | Refrigerators
My Ward, HMG - 1400 - 0, refridgerator coils will ice over
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Freezer compartment runs continuously
icemaker running continuously but producing no ice
May 03, 2009 | Maytag MTF2156GEB Top Freezer Refrigerator
Montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Jun 17, 2008 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
