Question about Ovens
BEKO DV62 MAIN OVEN FAN WORKS JUST GOES FLAT OUT HEAT TEMPERATURE NOT MAINTAINING
  • 74 Answers
SOURCE: Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Posted on Jan 18, 2006
SOURCE: oven switching off
Hello, this is a commom problem. The cooling fan is not working correctly and you need a new controller. The part number is 8996619267611 and costs about £28.00.
Posted on May 30, 2007
  • 338 Answers
SOURCE: oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
SOURCE: my oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Posted on Sep 17, 2009
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
Jan 14, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
My oven turns off on me after only a minute never heating up fully
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Sep 18, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
