CAUSE
loadTOCNode(1, 'cause');
During initialization, devices are reset too soon after they are
powered on. In this situation, some devices may use the wrong connector.
Solution:
Power Management system can sometimes cause issues. follow these instructions:
Right-click on My Computer/Properties/Hardware Tab/Device Manager. Now
look for the Universal Serial Bus controllers tree....then expand it.
You should see a number of USB Root Hub insertions. Right-click one of
them/properties/Power Management. Take the check out of the box labeled
"Allow the computer to turn off this device to save power".
If you still get "Usb device not recognized" in Windows and the above solution doesn't work for you, there might be other causes: A) USB device worked before but suddenly stopped working:
The following solution might be applicable: 1) Remove all oem*.inf files = 1. Click start and click run then under the run line type in the command “cmd” (without the quotation marks) 2. In the command line, type in the following (without the quotes) and press enter after each command: “cd \windows\inf” “ren infcache.1 *.old” “ren oem*.inf *.old” “del C:\windows\setupapi.log” 2) Removing all entries under HKEY_LOCAL_MACHINE/Enum/USB that start with VID == Removing the VID entries from the registry will cause them to be redetected at restart. CAUTION:
If you have a USB keyboard or mouse, do not remove the VID entry for
these devices, otherwise, Windows may not restart correctly. 1. Click Start and click Run. Type regedit and click OK. The Registry Editor window will open. 2. Go to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB. 3. Highlight and delete all the VID_…. entries. Permissions may be set allowing the deletion of the VID_ entries by following the steps below: a)Right-click the key to be deleted, and then click Permissions. The VID_… Permissions window will open. b)With Everyone highlighted in the Group or User name section, select Full Control in the Permissions section. c)Click Apply, and then click OK. 4. Turn off the computer.
Reconnect the USB device to the computer system: == 1. With the computer system turned off, reconnect the USB hub to the the USB port. 2.Restart the computer. 3.A New Hardware Detected window should open and reload the drivers. ------------------------------------------------------------------------------------- low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Some great ideas, good to know about the power management. I unchecked the boxes, but unfortunately, it's still not recognized. Any other ideas for Seagate FreeAgent Go? Thanks
Wont power up at all but have second drive and it`s ok also when i use 2nd power to 1st drive, 1st...
(More)
Wont power up at all but have second drive and it`s ok also when i use 2nd power to 1st drive, 1st drive works fine. power lead seams to be the problem
need to find a zip drive for my Akaii s5000 sampler with scuzzi drive port. I think it is a 25 pin...
(More)
need to find a zip drive for my Akaii s5000 sampler with scuzzi drive port. I think it is a 25 pin scuzzi.
I have a Lacie 2 Big Quadra. I can see them under device manager, but not disk management. I need to...
(More)
I have a Lacie 2 Big Quadra. I can see them under device manager, but not disk management. I need to format this drive. How do I do it? The operating system is windows xp.
Does this hard drive work with older USB 1.1 ports? Or do I need to find a PCI card with USB 2.0...
(More)
Does this hard drive work with older USB 1.1 ports? Or do I need to find a PCI card with USB 2.0 ports... - SmartDisk 80gb External Hard Drive ( Model # USBFP80P )
