Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
How to get to drain to clear backed up water?
    Problem Solver:
  • 12 Answers
You have to unscrew the front grill and under the coil there is a drain pan,look to the side between the electricals and the coil and you'll see the drainout for the condensate.u have to blow out from there:-)
Posted on Jul 07, 2010
  • mommac17 Jul 11, 2011
    Can someone clarify how to blow into the drainline? We were able to siphon out the water in the drainpan, but couldn't figure out how to check if the drainline is clogged.
How to clear a blockage in the drainage tube from the soap dispenser to the tub?
best to take the top off by removing the bolts in the back the slide it to the back then off.you then can get to the hose and remove it.
May 04, 2014 | Samsung Washing Machines
The water drains out of my Maytag Atlantis washer, but water backs up in the drain pipe. I have had a plumber run a snake and cleared the drain, but water still backs up. Is there anything that coul
The wall box outlet probably is about 1-1/2 in. in diameter. If it was snaked clear then there may be blockage in the main sewer line. In my case, there is a 90 degree bend that gets blocked periodically and causes the washing machine discharge to back up
Feb 08, 2013 | Washing Machines
Water in bottom of refrigerator
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpfu please VOTE FOR ME.
IMUFO2
Leo Ponder
imufo2@sbcglobal.net
Jul 26, 2011 | Refrigerators
Amana refrigerator model TX18QW excessive moisture , bottom of refrigerator fills up with water
IMUFO2
Leo Ponder
Jul 26, 2011 | Amana Refrigerators
Water seems to be leaking from freezer into refrigerator
If this was helpful please rate me.
IMUFO2
Leo Ponder
Jul 24, 2011 | Whirlpool Refrigerators
Water dripping on the top shelf constantly
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Jul 23, 2011 | Kenmore Refrigerators
Water drips from opening under freezer compartment into refrigerator area
IMUFO2
Jul 22, 2011 | Whirlpool Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
255 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
