Question about OTC Transmission Output Shaft End Yoke Remover 7075
My 1996 mazda mx5 is stuck in reverse/ I have the transmission out and on the bench. What do I look for? Wolfman
  • 487 Answers
Hi, well done for getting the transmission out. I take it this is an automatic? after drianing remove all compnents and replace with new ones in the same sequence they were removed. Its never as simple as we wish it to be, sorry for that. A Halfords manual for an automatic car will assist you!
Posted on Jul 07, 2010
Throw out bearing stuck in miata mx5
Hi, The throw out bearing should not have been affected with anything that you have described.
Quick note about bleeding: Bench bleed the master cylinder, then never let it run dry.
Anyways, you seem to have too many things happening at once. I worry about the clutch itself. When they wear, travels of things line throwout bearings become excessive.
If by stuck you mean beyond fully extended, certainly a clutch.
If by stuck you mean it is released and will not engage, maybe not a clutch...Make sense?
Essentially, you need the clutch to work correctly, sometimes you just gotta rip it apart and redo it.
Dec 12, 2012 | 1996 Mazda MX-5 Miata
2001 mazda transmission problems will not catch a gear
It
can be issue with gears or problem with transmission and needs to be rebuilt.
Also get the tranny fluid checked. If it\'s low, then such problems
occurs.
To
troubleshoot these types of issues, check the actual solved problems with these
types of issues.
There
are solved help links provided below: -------
Click
the link below and go through the details and diagrams to troubleshoot the problem:
2003 Lexus RX300:
Transmission Fluid Burnt Brown and not Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
2000 Toyota Camry:
Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission
Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse,
acts like it\'s in neutral?
http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh
Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into
reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in
reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift
To Reverse?
http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission,
with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When
Transmission is Shifted to Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode
Fuse number 27 blows on Ford Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
These
will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
1991 mazda mx5 eunos roadster radiator clogged with oil
Your radiator is leaking internally, leaking transmission fluid from the transmission fluid cooler into the radiator where the coolant is. You can't fix it, just get the radiator replaced and then flush the coolant.
Mar 08, 2017 | Mazda MX-5 Miata Cars & Trucks
Where is the intirior fuse box on 1996 mazda miata mx5?
On the drivers side of the car. Look behind the hood release and you should see a little black cover explaining which fuse is what.
Sep 07, 2010 | 1996 Mazda MX-5 Miata
626 stuck in reverse.
look down on top of the transmission you should see a flat lever, just click it until u are in neutral
Jul 31, 2010 | 2000 Mazda 626
Manual window winder just spinning and not opening window. My car is a Mazda MX5 Mark 1 1.8 1996 model.
You either need a new window crank itself, the inside of the crank could be stripped, you move the crank and out at it to see if the splines are wore away. Or your window regulator, inside the door, has gone bad and would need replaced.
Mar 15, 2010 | 1996 Mazda MX-5 Miata
How can I verify the transmission oil 1991 Miata MX5
If it is a whining sound, you may want to check the U joint.
May 25, 2009 | 1991 Mazda MX-5
Radio code miata locked
try either 1414 or 0532. on my mx5 2003 UK its 1414
Apr 12, 2009 | 1996 Mazda MX-5 Miata
1989 Mazda MX5 - Right tail lights not working
check globe ,wiggle wires,check fuse clean light housing
Oct 05, 2008 | 1990 Mazda MX-5
OTC Transmission Output Shaft End Yoke Remover 7075 Logo
103 people viewed this question
Top OTC Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an OTC Measuring Tool and Sensor Expert? Answer questions, earn points and help others
