Question about Harman Kardon AVR 230 Receiver
****** kardon avr 230 keeps going into protect mode. It's not the speakers.
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: I have a Harmon Kardon
please check all speaker cables for short circuit in receiver side or in the speaker side itself.
Posted on Jun 25, 2008
  • 4234 Answers
SOURCE: Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Posted on Dec 16, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
Can I connect 4 ohms speakers on the AVR 230? Thanks
Hello
Output impedence of 95% of Herman Kardon sets are desighed for 6 Ohms speaker. There is an output speaker sensor circutary it it which sense the impedence of the connected speaker. it is a built in feedback circuit and is ment for protection for both speakers and power amplifier section of the amp. If you connect a 4 Ohms speaker, the set will sense it and there is a chance to get it tripped as you increase the volume. Just connect and check. Advance the volume of the set very gently. If tripping occurs or it just cut off as soon as switch ON, never connect it again. OK.
Jul 27, 2011 | Harman Kardon AVR 230 Receiver
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Reciver is going to protection mode and sound turns off
is some speakers is defective, or not present (connected), check all cables
Jun 06, 2010 | Harman Kardon AVR 340 Receiver
Can I conect harman Kardon avr 230 to apple tv
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
Protect flashing on screen
Output amp needs repair or you have shorted speaker wire or bad speaker. Disconnect speakers. If still going into protect mode after turning reciever back on then have amp repaired.
Nov 20, 2009 | Harman Kardon AVR 65 Receiver
Harman Kardon AVR 230 Receiver Volume
You are overdriving the amp, they were never meant to be played at that volume despite the fact they will go to that level. Your only hope is to buy more efficient speakers or a stronger amp.
Apr 04, 2009 | Harman Kardon AVR 230 Receiver
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
Unit keeps going into protection as soon as its powered up.
Replace the audio amplifiers ICs they are damaged thats why the amplifier protect himself of a greater damage.
Apr 24, 2008 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 230 Receiver Logo
233 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
