I cannot switch on my Acer travelmate 283XC. The battery went flat and I have now plugged it in the wall but when I press the power button nothing happens...
  • 111 Answers
Try this; Disconnect from the AC outlet rmove the dc plug from the jack. Remove the Battery and wait for 5 mins and plug in the AC? DC adaptor without the battery. If the Laptop runs, then wait for the Windows to totally boot up and while running try to put back the battery and observe if it still charges. If not then try to replace the battery with a new one.
hope this helps.
Posted on Apr 18, 2008
My acer Travelmate 242lc will not power on
First think , has it been dropped, jarred, banged, .....you get the idea? Does it continue to blink, the HDD? Do you see a "ghost image" in the monitor in a bright light? Do you here sounds? You say "nothing else happens", meaning the light stops blinking? Shut down, unplug, remove battery, plug in, try to boot noemally.
Nov 16, 2012 | Acer TravelMate 242LC Notebook
Acer 2480 2247 won't power up -no lights no nothing, pwr supply is not the problem,lid close switch isn't stuck ,pwr. on switch seems fine and power supply jack on motherboard is not broken
Remove the main battery and the power supply, allow several minutes to get rid of any residual charge, now plug the power supply adapter back in and press power "leave battery out" is there any change? if not! remove power supply, now! press and hold power for 60 seconds to reset the laptop. Next install main battery back in and the power supply adapter, power up! if no change, the motherboard is the problem.
Mar 07, 2011 | Acer TravelMate 2480-2779 Notebook
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
I am unable to power on laptop. I got it to power up and then it went off again?
try takeing laptop battery out and power lead then hold power button pressed for up to a minute plug your lead and battery back in then try to boot up ;)
Mar 08, 2010 | Acer TravelMate 8200 Notebook
Travelmate 2300 does not boot up ... pressing the power button (with battery installed and with AC adapter plugged in) momentarily starts the internal drive ... then it gos quiet. Power light remains on...
Turn the system off....remove the battery from the system...connect the system to power adaptor ONLY.. the keep pressing the power button for about 15-20 seconds...then try to turn on...check if the system boots... let me know if the system works or not
Jan 15, 2010 | Acer TravelMate 2300 Notebook
Acer 5570 - Power switch is not working
Try removing the power supply (from the wall) and the battery pack. Hold down the power button for 30 seconds. Plug the mains power (from the wall) back in and then press the power button. It should work. Then you can replace your battery pack. Don't know why it works but it has worked for me in the past. Good luck!
Aug 01, 2009 | Acer Aspire 5520-5908 Notebook
No power
laptops don't powerup either because the battery isn't full, or it isn't plugged to the mains using the lead. if you think the above is fine then it must be because the laptops isn't accepting power in, either because of the motherboard has died, the chips have burned or the power button is faulty. if it's working using the battery but not using the charger then you need a DC socket repair. if it's plugged to the mains but there is no sign of any lights you're likely to have lost your motherboard. if your laptop does start but you see nothing on the screen its usualy the memory ram or the screen or the motherboard, plug it into an external screen and see what happens
this isn't something you can find a solution for in here, the best way is to take it to your repair shop
an independent one will do, or else I recommend a website which collects it and does it for you
cheaptofix.co.uk
I hope this helps. Please rate me.
>> www.laptopquestions.co.uk
Mar 08, 2009 | Acer TravelMate 2480-2968 Notebook
No switch on
Removing the battery for a long period of time is a huge no-no if the computer is not plugged into the wall
Plug it into the wall and try again
Jul 15, 2008 | Acer TravelMate 4000LCi Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
